Originally posted by timw4mail 1. My thoughts on build quality / functionality
- K lenses - the most well-built Asahi K-mount lenses
- M lenses - cheaped out and compacted K lenses
- A lenses - In between K and M in quality, adds auto aperture in the "A" setting, otherwise same as K and M lenses in functionality
2. As far as A lenses go: Aren't they just as annoying to use on a DSLR if you set the aperture manually? The aperture doesn't seem to get communicated to the camera except in the 'A' setting.
3. Is there a good fix for an M-series rubber grip that is loose? I have two lenses with this problem.
4. The Sears Auto MC 50/1.7 seems to be better in build quality and ergonomics than the Pentax M 50/1.7, with the exception of the aperture ring.
I own quite a few K and M lenses, and a few A series too. I would regard the Ms as only slightly behind the Ks in build quality, and that's probably due only to the higher weight (more metal) of the Ks giving them a more robust feel. Ms are without a doubt better built than As, though you need to bear in mind that the A series lenses, like the M series cameras, were the first series to introduce variations in build quality across the series. As such, it's more difficult to generalise the build quality, because it depends on the lens. The A series 50mm f/1.7 and f/1.4 lenses are quite poorly built, while the 28mm f/2.8 and the 50mm f/2.8 macro are much better.
I always use the A setting on a DSLR when available, there's no reason not to, and some A series lenses' aperture rings break and become unusable or very gritty with age, so best not to move them unless really necessary. My A28mm f/2.8 over-exposes by at least 0.7 EV when in A mode on a DSLR but exposure comp works fine to solve the problem.
I have a few lenses which equal or beat the old K/M series build quality (namely a Vivitar 28/2 and an Auto-Revuenon 50/1.4) but most third-party lenses are not as good in that respect.
