Originally posted by mikesbike
ISO 500 may not be enough for subjects which might move, or maybe your own movement, especially in low lighting. You have to keep track of your shutter speed in that situation. Before making a focus adjustment it is necessary to run a proper focus test.
The barrel should not be crooked. If you bought the lens recently, I would say return it for replacement. Otherwise, send it to Pentax to have it examined.
The train was pulling out, and I used TAv to fix shutter at 1/640s and aperture at f6.3. The camera have chosen ISO 500 on itself.
通过我的 Nexus 6P 上的 Tapatalk发言
---------- Post added 06-29-17 at 11:54 PM ----------
Originally posted by ruggiex
Mine was producing similar image until I did focus adjustment on my camera. I needed +5 in my case. Also, I find that first focus confirmation tend not to be complete in focus and it would readjust itself a bit and then it is spot on. I don't know how 'normal' that is. (Edit: actually this is true only because I'm always in AF.C mode. AF.S doesn't seem to have this problem.)
But if the barrel isn't even straight, you should be able to see uneven sharpness if shooting something flat.
I have used AF.A central point only, with back button focus. And I always shoot prefocus with the smallest possible aperture.
