07-08-2017, 05:42 AM   #1
SMC Pentax-DA 35mm F2.8 Limited Macro on K-1 in FF Modus
Hello
I today did some testing mit my SMC Pentax-DA 35mm F2.8 Limited Macro on the K-1.
It was recognized as APS-C lens. When i switch it manually to FF Mode, it works fine! I see no vignetting at all!
Has someone experience the same
Gérard
07-08-2017, 05:54 AM   #2
Na Horuk's Avatar
Yeah, I think there were reports that the DA 35mm f2.8 macro covers the FF image but only at some focus distances and apertures. So try focusing to infinity, then to minimum focus distance and something in between. You will get suboptimal corners in some focus distances, and completely black corners on some other. And aperture also plays some effect. You can try f2.8, f7.1, f16 at each focus distance to see how the image circle changes.
Feel free to post some sample photos to answer this question once and for all
Edit: Here is a really old thread with an test of DA 35mm macro on full frame film camera:
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/179269-tes...ull-frame.html
This test might not be enough to give the full story, but it is pretty decent. Someone with a K-1 could redo the tests much faster than someone with a film camera
07-08-2017, 05:58 AM   #3
jddwoods's Avatar
I am definitely dialed into this thread. I have a DA 35 macro and am very interested if it covers FF. I am planning to upgrade my K-5 in the next 12 months and if it is FF compatible, even under certain conditions, this could sway me in what I upgrade to. The DA 35 Macro SMC is one of my favorite lenses.
07-08-2017, 06:32 AM   #4
You can get away with using this lens in FF mode, but IMHO it stops being a Limited as far as image quality goes. Purple fringing can easily occur outside of the APS-C image area. At wide apertures, corner sharpness is poor, while at narrow apertures and close focusing distances, corner vignetting intensifies, though nothing gets fully cut off unless you deploy the hood. The edges are really quite good after you stop down past F4, though. If you can settle with the corners looking a little funky the rest shouldn't matter too much when shooting macros.
35mm, f2.8, f2.8 limited macro, ff, k-1, k-1 in ff, k-mount, macro on k-1, pentax lens, pentax-da, pentax-da 35mm f2.8, slr lens, smc pentax-da 35mm
For Sale - Sold: SMC Pentax-DA 35mm F2.8 Limited Macro nixxo2002 Sold Items 10 08-30-2016 11:43 PM
My first Limited lens: the SMC Pentax-DA 35mm F2.8 Limited Macro PALADIN85020 Pentax SLR Lens Discussion 12 07-13-2014 09:01 PM
For Sale - Sold: DA Limited 21mm / DA Limited 35mm Macro / DA Limited 70mm top-quark Sold Items 3 04-23-2013 05:01 AM
Wanted - Acquired: SMC Pentax 28mm F3.5, SMC Pentax-DA 35mm F2.4 AL, SMC Pentax-F 28mm F2.8 TMoneytron Sold Items 8 07-15-2012 02:54 PM
Exposure Correction in Modus M (K10D) vadim23 Pentax DSLR Discussion 19 04-10-2007 04:49 AM
All times are GMT -7. The time now is 10:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
