07-16-2017, 08:04 AM   #16
Otis Memorial Pentaxian
photolady95's Avatar
Just so you know, the DCR-150 works best with lenses longer than 100mm, while the DCR-250 works best with lens that are shorter then 100mm.
07-16-2017, 10:41 AM   #17
UncleVanya's Avatar
Use this page to see what kinds of results to expect:
Macro Extension Tubes & Close-up Lenses
Scroll past the extension tube calculator to the close up filter one. Also bring a tripod if you plan to use this on things that are not flat. Depth of field drops precipitously when using Macro. You need a steady hand a lot of light and likely a tripod to take pictures most of the time due to the high f/stop you will want to use.
Some numbers to help you:
Max magnification for the 18-135 is 0.24x (presumably at 135mm and minimum focus distance. Plugging that in to the calculator gives just over 1:1 (1.04x) which should be nice. Assuming the 70-300 is a modern sigma they claim 1:4.1 and 1:2 in macro mode. This should translate into as much as 2.6x and at least 2x lifesize.
I think the DCR-150 is perfect. Even on the shorter lens it fills the gap between your 0.24x and up to 1x It fits the filter threads with a quick snap on and off adapter etc.
BUT long term if you find you love macro you may want a dedicated lens for that. I have the DFA 100 WR and I have owned many macro lenses. I also own the DCR-150 and 250 and a bellows and extension tubes etc. All of these methods have tradeoffs. A macro lens is quite flexible but carrying the Raynox in your pocket is a simple solution for when you might shoot something up close but it isn't your main plan.
amazon, camera, dcr-150, lens, macro, macro lens, pentax help, photography, raynox, suggestions, suggestions for macro, time, troubleshooting, tuesday
Macro lens suggestions please TraciA Pentax SLR Lens Discussion 22 11-29-2016 12:37 PM
Macro Macro lens suggestions victormeldrew Photographic Technique 14 10-27-2016 11:21 AM
Lens tests on K-1 : 15-30, 24-70, 70-200, 31, 43, 77, 100 Macro, 28-70 and 80-200 Mistral75 Pentax SLR Lens Discussion 14 06-28-2016 11:46 AM
For Sale - Sold: Pentax FA 100-300, FA 70-200, M 28mm; Sigma EX 28-70, Apo 70-300; Tamron Di LD 70-300 stillnk Sold Items 17 04-08-2012 11:39 AM
Suggestions on finding the Matched 1:1 Macro Adapter for Cosina 100mm f/3.5 Macro? pentaxk1000denver Pentax SLR Lens Discussion 10 06-18-2011 02:41 PM
All times are GMT -7. The time now is 01:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
