08-18-2008, 04:31 PM   #1
K20D's Avatar
Tamron SP 500mm on K10D
I was wondering if anyone has used a Tamron SP 500mm (the mirrored one) lens with the K10D with any success. I can use my other SP lenses if the lens has the AE option on the f stop ring.
If anybody has discovered a method to make this lens work, please let me know.
08-18-2008, 05:13 PM   #2
Wheatfield's Avatar
Well yes, I've made it work quite well.
You have to use the green button kludge, IIRC.
Set camera to allow shutter release with lens off the A position, set camera to manual exposure and press the green button to set the shutter speed.
Adjust shutter speed or ISO as required to get the correct exposure.
08-18-2008, 05:26 PM   #3
K20D's Avatar
I am trying to use those settings, and as far as I can tell, I'm doing something wrong.
1) Ive got the body on 'M' mode.
2) The upped LCD screen is displaying a flashing 'F--', and nothing seems to change this.
3) Green button 'kludge?' Is this a typo?
08-18-2008, 06:25 PM   #4
borno's Avatar
manual aperture lenses will show f--- because you use the aperture ring to change f-stops. A mirror lens has no aperture blades so you shoot wide open and should be able to use green button in m mode to set shutter speed but you program camera for tv shift when using green button in custom menu. I think A mode should work if you want auto shutter speed selection.
hope this helps
08-18-2008, 06:34 PM   #5
K20D's Avatar
Thanks for the help. I can't find anything in the manual for "tv shift". Could you please advise where this is located?
08-18-2008, 06:41 PM   #6
borno's Avatar
under custom menu you can set green button function in manual for tv shift and it will set shutter speed
p 158 for k10d
08-18-2008, 07:49 PM   #7
Moved to the SLR forum.
08-18-2008, 08:34 PM   #8
K20D's Avatar
Thanks for the help. Funny enough, the problem turned out to be my adapt-all. As soon as I removed it, the lens worked fine in manual mode.
500mm, k-mount, k10d, lens, pentax lens, slr lens, sp, tamron, tamron sp 500mm
First photo with my Tamron 500mm Silverkarn Pentax SLR Lens Discussion 7 09-19-2010 05:38 AM
2x teleconverter for Tamron SP 500mm.... Silverkarn Pentax SLR Lens Discussion 5 09-13-2010 03:39 PM
For Sale - Sold: Tamron 500mm f/8.0 (55bb), Tamron 28-70mm (44a), adaptall-2 p/k, Vivitar 283 f hinman Sold Items 7 03-03-2010 08:42 PM
Tamron SP 500mm f8, 55BB wilkin Pentax SLR Lens Discussion 15 03-07-2009 10:02 AM
All times are GMT -7. The time now is 08:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
