08-18-2008, 06:29 PM   #1
Shake reduction manual focus zoon lens
I have one Sears manual zoom lens focal lengh 80 to 200 mm. For the shake reductio to work OK which is the MM setting for it? I know that for the 50mm it is 50mm. I also have an interesting lens bought thru e-bay a 100-500 mm Samyang pentax/ricoh mount with A setting. (Almost brand new in the box missing manual)Seems to work fine with K100D without the pin problem. Any one may have an idea how to get the owners manual? Researched the net including Samyang web site without luck?
08-19-2008, 03:22 AM   #2
Lowell Goudge's Avatar
QuoteOriginally posted by juanacevedo Quote
for shake reduction there are a lot of differing opinions. If you are always shooting at one end of the zoom,either long or short, set it for that. you could also set it for the middle, to be on average close, or to minimum always, getting less benefit at the long end.
I usually set it for the niddle on a 70-210mm zoom
08-19-2008, 04:22 AM   #3
I'm with LG above, I set my pentax "A" 70-210 at about 120, not quite half, more like 1/3 into the zoom range. I probably miss greater SR on the long end, but I've not found any over compensation evident on the short end either. But if I know most of my shots will be longer I up it a bit to 150 or so.
As for the manual, sorry but I have no idea.
NaCl(but I'm not obsessive about it)H2O
08-19-2008, 11:55 AM   #4
Ballyclogh's Avatar
I have set my SR on the farthest end of my focal length with my manual lenses and that has worked great...I've had no issue if I need to go below the set SR focal length.
08-19-2008, 12:50 PM   #5
SR thanks
Appreciate for the inputs guys. I will do some testing with both methods,
Thanks again.
Juan
50mm, k-mount, lens, mm, pentax lens, samyang, shake, shake reduction, slr lens
K10D - Setting Shake Reduction Focal Length With Manual Focus Lenses? stewart_photo Photographic Technique 30 07-28-2016 12:52 AM
[k-x]How to enable shake reduction in video mode with manual lens? tiny Pentax DSLR Discussion 9 03-15-2010 07:56 PM
Manual lens focal length for shake reduction Riverlady Troubleshooting and Beginner Help 20 05-05-2009 03:16 PM
k20d + manual lens, tricky shake reduction question! Isaac314 Pentax DSLR Discussion 2 09-03-2008 09:35 AM
K10D shake reduction manual setting zoom lens chris hall Pentax DSLR Discussion 7 02-14-2008 08:38 AM
All times are GMT -7. The time now is 03:34 AM. | See also: NikonForums.com, part of our network of photo forums!
