Originally posted by chaos83 any opinion on the tamron? popphoto has a favorable review on it. id like a real world opinion
I have the Pentax DA 18-250mm, which is the same lens as far as I can tell. My main kit consists of the 16-45mm, 55-300mm, 50mm 1.4 and Raynox 250. The whole kit, including my K100DS fits in a bag smaller than most ladies' purses. I only use the 18-250mm on occasions when I strongly want to avoid lens changes. As a telephoto lens, the 55-300mm seriously outdoes it. The 18-250mm only reaches 250 mm at infinity focus. At close distances it provides less zoom than a 200 mm lens. For long zoom, there's really no comparison. The 55-300mm has significantly more reach, less CA, performs better at minimum apertures, and is sharper above 150 mm.
Calling the 18-250 a macro lens is deceiving. It's not a true macro lens, it just allows close focussing. Note that Tamron claims "macro" but Pentax doesn't. You can actually get tighter close-ups of flowers with the 55-300 than with the 18-250. Neither even begins to compare with the inexpensive Raynox, which allows true macro photography.
I have an original 18-55mm, which I expect will never be used again. The 18-250 beats it in sharpness and brightness, the 16-45 beats both at pretty much everything. The 18-250mm has zoom creep, high distortion at the wide end, and no quick-shift focus. From the tests I've seen online, the 18-55 II may have slightly better IQ than the 18-250 and is a much lighter lens.
The question is, do you want a versatile walking-around lens, or do you want to maximize performance? Unless your main priority is to avoid lens changes, my recommendation is to keep the 18-55 II and buy a DA 55-300mm and a Raynox 150 or 250. The cost is the same, you won't be duplicating a range that you already have, you'll achieve better telephoto and real macro performance. Having the 18-250mm is a lot of fun, but maybe not the best choice for you right now. Here are some photos from my first outing with the 18-250mm:
http://picasaweb.google.com/bonhommed/Pentax18250mm
Here's a review of the 55-300mm. Note the last paragraph.
http://www.popphoto.com/cameralenses/5469/pentax-da-55-300mm-f4-58.html
