08-21-2017, 11:55 AM   #1
cardinal43's Avatar
Step Down Ring Size.
I have a question regarding step up/down rings. I have never used a CPL and I was given a Hoya NXT 77mm CPL as a gift. In looking at my lenses, I have a Tamron 28-75mm (067mm), and a Tamron 70-300mm (062mm). As the CPL is 77mm, I will need a 77mm-67mm step down ring to fit the 28-75mm, and a 77mm-62mm step down ring to fit the 70-300mm - I think. In looking at different sources I don't see a 77mm - 62mm step down ring anywhere. Does anyone know if there is such a ring? I would appreciate any info you guys & ladies can provide. Thanks.
08-21-2017, 12:13 PM   #2
QuoteOriginally posted by cardinal43 Quote
Technically I think you want a step-up ring, not a step down ring. If you cant find a specific match you could theoretically cascade two step up rings, but you run the risk that it will vignette if the lens is wide angle.
EDIT:
https://www.bhphotovideo.com/c/product/809638-REG/Sensei_sur6277_62_77mm_Step_Up_Ring.html
https://www.bhphotovideo.com/c/product/809642-REG/Sensei_sur6777_67_77mm_Step_Up_Ring.html
08-21-2017, 12:39 PM   #3
cardinal43's Avatar
QuoteOriginally posted by abruzzi Quote
EDIT:
Sensei 62-77mm Step-Up Ring SUR-6277 B&H Photo Video
Sensei 67-77mm Step-Up Ring SUR-6777 B&H Photo Video
Thanks for the quick reply. I believe this is just what I was looking for.
70-300mm, 77mm, cpl, k-mount, pentax lens, slr lens, step, tamron
Good, inexpensive CPL filter and step-up / step-down rings BigMackCam Pentax SLR Lens Discussion 9 01-06-2017 06:08 AM
step down ring or step up ring ? dh4412 Troubleshooting and Beginner Help 5 04-14-2012 04:39 AM
General rule for step-up step-down rings? uchinakuri Pentax SLR Lens Discussion 2 06-18-2010 09:54 PM
step-up or step-down rings? ncrecordkeeper Pentax Camera and Field Accessories 8 05-13-2010 07:31 AM
Step up or Step down ring for FA 50mm f1.4 and filters. Xcom Pentax Camera and Field Accessories 4 05-11-2009 11:56 PM
All times are GMT -7. The time now is 01:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
