The Pentax rubber hood adds very little to the overall size when collapsed, about 3 or 4mm to the radius and maybe 1cm to the overall length. It pops up and down quite easily.
Do note that any filters you stick on after the hood will be offset a smidge more than necessary. Most likely it won't be an issue but I think you usually want them as close as possible to the front element (but not touching
This is probably obvious, but if you are using step up rings to attach filters to your FA50, the rubber hood
won't possibly won't extend past them.
