Originally posted by normhead I've always hoped someone would commission one of those. I'm sure I'd spend so much time getting it perfect I'd end up working for 25 cents an hour, but I'd still like to try.
But I have to ask, why would you buy a 20-40 if you are thinking of a K-1? I'm the opposite. My K-3 is my long glass wildlife/birds body, and my K-1 will be my wide angle/ landscape body. The 28-105 is wider on a K-1 than the 20-40 is on a K-3.
What do i do these days when I want 21 mm on a K-3? Shoot 35mm on a K-1.
What do i do when I want 750mm on a K-1? Shoot 500mm on a K-3.
Too true about the 25 cents, Norm. It would be stupid to try and argue that the various shows etc I do are a career, but it helps supplement my very prematurely taken pension from IBM and I like the challenges it throws up, even at 20p an hour ...
The 20-40/K3 is all about a more carefree usage of my APSC kit. I don't do wildlife/birds (as well) as you do, preferring static subjects, for this I take my FF kit and heavy tripod etc, which allows my to blow my prints up. This kit is my 'professional' kit. The APSC kit is either for a few longer FL landscapes often in poor weather (50-135), or a wander around the countryside, lightly, not aiming for 'masterpieces', more for illustrative use and lucky finds. In the back of my mind is always the nagging fear that I might have the opportunity to capture a large printable shoot, but an 'inferior' lens fitted, which is why I went for the Limited. Not having to take a tripod or at least a monopod for these wanderings is probably where I need 'help'.
A 28-105 on the K-1 would serve a similar, walkabout option, but I know I would not be especially relaxed about using my main camera in this way, and anyway the K3 needs to get some exercise ... Irrational or what
