Test the iris for stickiness by putting the aperture ring on a high f number and testing the movement of the iris holding the iris open with the aperture lever and then letting go. If the return spring isn't consistently and easily closing the iris there is a problem.
Repair: I am not familair with this lens. My thread on the viv 70-210mm gives an idea of what can be involved:
Vivitar (komine) 70-210mm, PK-A mount, sticky iris repair. - PentaxForums.com
Some diligent internet searching may pull up some disassembly info on this lens, or a similar tokina zoom. You only need access to the iris to then try a bit of solvent (coleman fuel/similar) to remove any oil/grease residues.
