Originally posted by BigMackCam I think - based on the majority of reports on this lens - that you've been lucky and have an extraordinarily good copy
In fairness, it is - after all - a consumer-grade kit lens, with build quality very much at that level. Nothing wrong with that, of course (I own and like several consumer-grade lenses myself), but - with respect - it's the last lens I'd recommend for a K-70 and KP covering this focal length range, except perhaps as a versatile economy option. It definitely has its uses, for sure, and I'd happily own one if I needed it. IQ aside, though, it can't compete in the range of use-cases where the DA*16-50 works, and given that the OP already has experience of such a fast lens, I'd personally be wary of recommending anything with variable aperture - especially where stopping down is necessary. There's also a pretty noticeable difference between 16mm and 18mm if the wide end is important...
totally agree... IQ of that lens for sure could not compete with the DA* and it aint fast either.
nonetheless its a lens that makes you smile and the AF speed is good for catching funny or remarkable moment (and that in FOCUS.)
(never experienced hunting on that "little bugger")
And for sure there is no need to argue, if you know your gear, you maybe take the same shot with a slower focusing lens... (but AFAIK both lenses are pretty much the same when focusing... So all this is "just sayin"! Sry, its been quite a while since I handled a 16-50 2.8 but my guts say the 18-50 is focusing a bit faster, correct me if I am wrong.)
And you are also right, that 2mm difference make a huge difference at the wide end.
just sayin, that he may be happy with that lens as a cheap replacement until we see a Double-PLM... (Dont know if hes doing production work or just fun shooting/hobby)
(i am sure RICOH will do something about AF-drive soon... whatever that tech will be called...) version of the DA* 16-50 2.8 ... just my 2 cents.
pic below was shot with the aformentioned lens (18-50 DC WR) (mounted on an older K-3 body)
at 30mm with the widest aperture possible at that length(F:4,5) for the 15th of a second(1/15s) - ISO 3200
(as mentioned in my review of the lens ... with harsh light coming from the left and WITHOUT a lenshood.)
