Originally posted by PenPusher I am aware that the most publicised changes in recent times have been to the coatings but as far as I am aware coatings remained the same for some considerable time.
Dunno. The SMC coatings got "silent" upgrades over the decades. And I think the DA lenses needed slightly different coatings due to digital sensors being different from film (more shiny). And then there are the HD and Aero coatings. You can see there might be differences in the colour of the light reflected off the coatings.
So, we are fairly certain that coatings have been changed throughout the years, but we don't know when the last update was, other than when SMC was changed to HD. Aperture blades on some of the newer lenses are also different, more rounded, possibly different materials than the old M and A versions.
The optical designs for the lenses OP mentions has been the same, but we don't know if there have been small tweaks, for example to optimize centre sharpness at the cost of edge sharpness - which makes sense for digital crop sensors. Or changing the angle of incidence of light, which might be important for digital sensors. The other possible change is change in machining and even glass materials. These things can change over the decades, because the machines might get upgrades, factories might be changed, etc. Materials can also have slight changes, because some might get more expensive or less expensive, or better combinations are developed, or some materials get restricted due to stricter environmental and safety standards..
The problem with the published diagrams is that they are not necessarily perfectly accurate in terms of sizes and distances.4
So the changes between M 50mm f1.7 (
design here) and DA 50mm f1.8 (
design here) might be really small (only aperture blade shape), or more drastic (coatings, small tweaks, differences in machining or materials). We just can't know for sure. But comparisons have shown the differences in optical output are really minimal. You can search for threads, as people have compared lenses from different generations
