Originally posted by BullsOnParade81 Sure I can talk to her and convince her to let you get one. I've found the trick to getting the lens you want is to buy it used and let her know what a great deal you got compared to new. Also as far as size goes it is a large heavy lens but it depends on your age. I am in my mid 30s so I carry lots of camera gear no problem. If you are an elderly man than it may be too heavy for you.
That's a trick I use a lot...
I'm 42 so I still have something to give as far as carrying weight. My usual backpack has the K1, Sigma 70-200, Sigma 10-20 HSM, Sigma 50 1.4, Benro Travel Angel tripod. In case I get the 15-30 I'll need to pair it down a little, depending on the tasks. Needless to say I'll sell the 10-20 once done.
---------- Post added 09-09-17 at 10:53 AM ----------
Originally posted by mcgregni Isn't that the entire point of such a lens .... I mean, everything else should be secondary, and if it isn't then presumably its not the right lens.
Do you have one? How does that feel when carrying it around?
---------- Post added 09-09-17 at 10:54 AM ----------
Originally posted by DeadJohn I like it a lot. It's heavy, but a manageable kit to carry on long hikes when paired with the light 28-105.
If I need to use a filter I put it on the 28-105. The 15-30 remains filterless. Polarizers give uneven skies when going too wide. For long exposures with the 15-30 I use the K-1 multishot averaging shutter mode rather than ND filter. Bracketing and Photoshop layers fill in for graduated filters.
Physical filter solutions for the 15-30 need too much bag space for me.
Can you expand on that technique with the K1? I mean, I use bracketing and Photoshop combine very often but don't know about that mustishot averaging shutter technique...
Thanx
