I would recommend you consider renting some equipment and doing your own testing before investing in new equipment
I have used Lensrentals.com with good results
there are other companies
be sure to purchase the best protection program offered
once you have conducted your own testing of a camera body and/or lenses, you will have a much better idea of what to look for
__________________
this chart will give you info on what camera body to use with the lenses you might want to consider:
Pentax Lens Compatibility Chart
Copyright 2006-2016 Mosphotos.com. All rights reserved.
Pentax bayonet lenses labeled "SMC Pentax" are referred to as "K" lenses in the table below. Other Pentax bayonet lenses have the lens designation as a part of their name as in "SMC Pentax-FA."
Note that "star" lenses work like their "non-star" counterparts: DA* lenses work like DA lenses, FA* like FA, F* like F, A* like A, and M* like M.
Exceptions: FA and F "soft" lenses behave like M lenses in terms of metering.
The Pentax Camera Lens Compatibility Chart
as noted, the newest 55-300mm - DA 55-300mm EDPLM WR RE
will only work properly with the following camera bodies:
The Pentax K-50, K-S1, K-S2, K-3, K-3 II, and K-1 are supported via a camera firmware update; the Pentax K-70, Pentax KP and all 2017 or newer bodies will work out of the box.
Read more at:
https://www.pentaxforums.com/reviews/hd-pentax-da-55-300mm-f45-63-ed-plm-wr/...#ixzz5NzWSC1kk
