As a collector's item, it could well be worth the $7k asking price, but one of today's converted DSLRs could put it to shame. The Nocta used a vacuum tube converter to convert an "electron image" created by a front electron-emissive element to a visible image using a phosphorescent screen which gave a grainy, low resolution image. That image was captured on film. These tubes were fairly sensitive to IR and could go a bit further into the IR range than today's DSLR sensors. They required a high voltage supply (15 to 20 kilovolts) and some had x-ray emission issues (leaded glass was used in the lenses of some direct view IR scopes). At that time, it was the only practical way to see in infrared realtime. There were infrared goggles used in many film processing labs so loading and handling of film could be done (not infrared film!). Nowadays film labs use ................
If I were a camera collector, would probably be clamoring to get a Nocta for my collection, but if you want an IR camera, there are substantially better options today.
