Show Printable Version 9 Likes Search this Thread
10-02-2017, 09:23 AM   #1
All Purpose Lens
Hello, I'm looking for some advice.
My wife currently uses a Pentax K5 IIS with a Pentax 18-270 lens. Now although she likes the variability of the focal length she is starting to get a bit more adventurous in the shots she takes and is becoming a little frustrated with the speed of the lens, both from an aperture and how long it takes to focus. Now she has tried the same lens with a K3 and that doesn't seem to help and has tried my 16-50 F2.8 which is much better but don't give her the all in one focal range.
Does anyone have any suggestions on which lens might help. It doesn't have to be fully 18-270, something a bit shorter, probably at the long end might suffice. But as long as it's a bit faster focussing than the 18-270.
Cheers
Tim
10-02-2017, 09:30 AM   #2
Otis Memorial Pentaxian
QuoteOriginally posted by tjstimbo Quote
Cheers
Tim
you don't mention price range but i would suggest da60-250.... a big difference in what she currently has in quality and price
10-02-2017, 09:36 AM   #3
QuoteOriginally posted by pearsaab Quote
Sorry - price isn't a factor. I have some older lenses as well but don't want to make things too heavy I'll get her to try your suggestion. Also if I can get her to be able to change lenses with confidence I could pair the 60-250 with the 16-50.
Cheers
Tim
10-02-2017, 10:11 AM   #4
Senior Moderator
Parallax's Avatar
This is neither news nor rumor.
Moved to the proper forum.
10-02-2017, 10:43 AM   #5
Bad Boy's Avatar
You mentioned, being comfortable with changing lenses. That has many advantages. Using only one lens will be limiting. The 18-270 is versatile until you need wider aperture.
Another option is to continue to use the 18-270 when you do not need the wide aperture and have some fast light weight primes for when you need the faster glass. Could start with a DA 35 and DA 50. They are good, light, and affordable. With primes one can learn to zoom with your feet instead of your fingers or a little cropping. What is nice about this is the lighter weight and size.
A couple of F2.8 zooms would also be a good option if size and weight is not an issue.
My wife is learning with the 18-55 kit lens. She is starting to use the DA 35 or DA 50 for shooting the grand kids indoors.
10-02-2017, 10:43 AM - 1 Like   #6
VoiceOfReason's Avatar
The 18-135 will focus pretty fast, however it is still a slower aperture lens at f/3.5-5.6. The closest you might get is the DFA 24-70 f/2.8 for the most range and faster aperture. You're not going to get a superzoom with a fast constant aperture.
10-02-2017, 10:54 AM - 2 Likes   #7
Madaboutpix's Avatar
Your wife may want an HD16-85. Not much faster aperture-wise, but likely faster to focus. Probably the closest you get to a premium-quality-all-purpose lens in the K Mount line-up right now.
For a cheapo but excellent-IQ fast prime, you may want to check out the DA50. But be warned, that one may lead her to develop a taste for prime lenses ...
PENTAX K-3  Photo
10-02-2017, 10:55 AM   #8
Cheers
Tim
The DA 16-85mm or 18-135mm are both good choices, with the former being a bit wider and having better image quality at the expense of less reach.
If/when you upgrade the body, you might also want to consider the 55-300mm PLM, which is insanely fast to focus.
10-02-2017, 11:15 AM   #9
dsmithhfx's Avatar
Prime. A 35mm focal length is reckoned to be the most versatile for FF, so for a 1.5x crop factor a 24mm would do nicely. @f2.8 reasonably fast without breaking the bank. Excellent DoF, so pre-focusing/zone focusing becomes feasible.
10-02-2017, 11:51 AM   #10
UncleVanya's Avatar
Have her look through her pictures. Have her pull the focal length of the ones she is most drawn to. If they cluster around any numbers then a zoom that covers those is probably OK - if not then you may need two lenses. The 16-50 and 50-135 are excellent lenses but neither is a speed demon on focus. The 60-250 is a little slower (f/4 vs. f/2.8) and again no speed demon on focus.
The 16-85 (or 18-135) paired up with the PLM version of the 55-300 f/4.5-f/6.3 is a quick focusing wide range combo but not super fast from a light gathering perspective.
The DFA 24-70 and DFA 70-200 are superb large fast lenses that might interest her but they are probably overkil as they are full frame designed for use on the K-1.
10-02-2017, 11:55 AM - 1 Like   #11
disconnekt's Avatar
There's the 17-70mm f4 and the 60-250mm f4
10-02-2017, 12:02 PM - 1 Like   #12
builttospill's Avatar
Uncle makes a great suggestion. Review focal lengths on some shots and then get the first FA Limited lens closest to that range. Then buy the other two FA Limited lenses. They are small, lightweight, and very high quality.
10-02-2017, 12:08 PM   #13
My current all purpose lens is the FA* 24 F2.0 on APS-C.
I can suggest the 18-135 also and I like builttospill's suggestion to get the FA limiteds.
10-02-2017, 12:57 PM   #14
david94903's Avatar
Your wife might want to look at what focal length/range the majority of her pictures are taken at, and use that as a benchmark spot to start from. I used to use the 16-50mm as my daily driver but disliked the bulkiness. I looked at how I was shooting, and discovered I shot 80% of my pics at 16mm, so I dumped the 16-50 and bought a DA15mm, love the size and quality of that lens. Additionally, my wife has a 18-135, which is a very versatile lens, so I bought that as my second. So now if I'm out with my APS sensor, I only bring two lenses, and most of the time the DA15 lives on the body.
10-02-2017, 02:03 PM - 1 Like   #15
Excellent thanks all for your replies. I think the best advice is to do what Uncle suggests and look at the popular focal length of the pictures taken. Never even thought of the 55-300! Will take a look at it. The key is getting her to change lenses with confidence then I have a bag full of primes she can consider.
Cheers
Tim
bit, lens, pentax, pentax news, pentax rumors
Best all purpose lens PhotoHeron Pentax SLR Lens Discussion 21 03-13-2016 11:14 AM
All-purpose basic lens set Nadir Pentax SLR Lens Discussion 18 03-07-2014 09:42 AM
General purpose all-in-one day to day usage lens iAndroid Pentax K-r 15 05-20-2013 06:51 AM
Best all-purpose bang for 150 bucks russell2pi Troubleshooting and Beginner Help 19 01-17-2013 04:51 PM
Looking for an all-purpose lens wedge Pentax SLR Lens Discussion 12 04-08-2010 06:17 AM
All times are GMT -7. The time now is 03:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
