10-04-2017, 10:13 AM   #1
FarmerJim's Avatar
Fixed Size (dimensions) Lens?
I really like the fixed size of my DA* 50-135 lens. When zooming or focusing the lens barrel does not extend (or rotate). It seems like this enhances the weather sealing of the lens, and without the air being pulled into or pushed out of the lens when extending or contracting, a design that "causes" less dust to appear in the lens.
Do my thoughts make sense? Is this something that can be measured?
Does Pentax make any other fixed length (zoom or prime) lenses that do not extend when changing focal length or focusing (internal focusing and internal zooming)?
Thanks for any thoughts or information!
10-04-2017, 10:38 AM   #2
boriscleto's Avatar
The term you are looking for is internal zoom. Only one other current zoom is an internal zoom, the D FA* 70-200/2.8. The FA* 80-200/2.8 & F*/FA* 250-600/5.6 were internal zoom.
10-04-2017, 11:08 AM   #3
Seeker of Knowledge
aslyfox's Avatar
using the lens search tool you can access under " Lenses " above and filtering for " internal zoom " this is the result I got for zoom lenses both in and out of production
https://www.pentaxforums.com/lenssearch/?type=Zoom&inproduction=0&iz=1
six total
HD D FA 15-30mm F2.8
DA★ 50-135mm F2.8
HD D FA★ 70-200mm F2.8
the following are marked no longer in production:
FA★ 80-200mm F2.8
F★ 250-600mm F5.6
FA★ 250-600mm F5.6
10-04-2017, 11:49 AM   #4
boriscleto's Avatar
@Adam
The D FA 15-30 doesn't have the Int. Zoom icon in the database.
10-04-2017, 11:59 AM   #5
QuoteOriginally posted by boriscleto Quote
@Adam
Added, though those icons will soon be replaced since we have the lens specs in the new system. Thanks!
The 15-30mm is borderline IZ in my opinion, since the length doesn't change but you can see the element moving within the outer hood.
10-04-2017, 12:32 PM   #6
Na Horuk's Avatar
Internal zoom and internal focus. These features have their own pros and cons. It seems like most high end lenses these days have these designs. Some designs actually use both, moving the barrel as well as adjusting the ratio between elements. Lens barrels can be very complicated
In theory the internal mechanisms have some drawbacks I don't like, especially since I don't really use WR. But in practice, these are not very noticeable, at least not to most people
10-04-2017, 12:33 PM   #7
FarmerJim's Avatar
Thanks for the info.... I guess I hadn't noticed that I could select "Internal Focusing" and "Internal Zooming" on the lens search page.
k-mount, length, lens, pentax lens, size, slr lens
Image Dimensions jacamar Digital Processing, Software, and Printing 13 01-03-2017 01:20 PM
Why can two lenses of the same focal length and aperture has different dimensions FarmerJim General Photography 13 05-17-2016 01:13 PM
Question about apertures on zooms (fixed vs variable, why ever have fixed?) wibbly Pentax SLR Lens Discussion 17 02-16-2015 09:17 PM
Understanding perspective vs lens size vs sensor size (lens mechanics?) soycory Troubleshooting and Beginner Help 19 12-23-2014 07:40 AM
Question about pixel dimensions/image size etc. grayboy Troubleshooting and Beginner Help 6 10-07-2010 08:43 AM
All times are GMT -7. The time now is 03:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
