Originally posted by RobG OK, I'll need to do more research. From what I've seen in the interface, select mode selects a 9 point group from the 25 point matrix. I thought that it was still 9 points within the selected set.
If you look at the Expanded Area AF screens, you have Select S, M or L. The points the camera can use are shown in pink. The camera will initially try to focus with the point shown in red. You can move the red point around within the selected area. Some suggest to move it up for example for sports, to focus on a player's face instead of his jersey. When you half-press, the camera tries to find focus with the selected (red) point. If it does not find focus (i.e. if you do not take the shot), it will move to an adjacent point. Once you fully press, the subject is locked and tracked, by colour and shape.
Originally posted by RobG OK, but you have to take a photo to start tracking? Half depressing the shutter won't do it? Sorry to ask so many questions, but I want to be sure that I understand it correctly.
Yes, thanks for questioning that. I mis-spoke above, and I have made a correction in my earlier post. You need to take a photo to initiate tracking. The subject is registered as soon as you take the first shot. For that first shot, you must ensure that focus is exactly where you want it, otherwise you will have a string of misses. As soon as you let up on the shutter button, tracking stops.
This post on "focus bumping" is useful for understanding how to use tracking. Note that in point #2, he sets sensitivity for the longest delay. That would be
AF Hold High for Pentax. I've found that AF Hold Medium works well for BIF. I definitely needed AF Hold High for hockey:
http://www.birdphotographers.net/forums/showthread.php/1949-Bumping-the-focus-for-BIF
---------- Post added 2017-10-23 at 09:54 ----------
Originally posted by Canada_Rockies If one were to use the back focus AF button with shutter AF disabled, would tracking continue as long as the AF button was engaged? If that is a correct analysis, I know what I will be using from now on. I'm talking acquire focus with the AF button, and hold it.
I never use the back button for action shooting, but back button AF behaves the same way as a shutter half-press.
I can see that BBF was useful at one time, because it would allow you to rapidly switch from AF-S to AF-C. I've configured User1 mode for action, which allows me to change many things (shutter speed, aperture, EV, SR, etc), when I switch from stills to action. I don't see any advantage to BBF, and it is more clumsy for me than shooting the way I am accustomed, i.e. half-press for focus, fully depress to shoot.
