Originally posted by G and T My K3 and D FA 150-450 play nicely together on all settings including 9 point AF.
Could you possibly have the lenses AF limit switch set outside the distance needed for the scene?
The first time, the lens was set to focus limiting 6m-infinity and I was photographing aircraft in flight, so it should have been appropriate. The second time, I turned off the focus limiting and had the same result - lens went to minimum focus and stayed there. What firmware does your camera have, please?
---------- Post added 18-10-17 at 09:36 AM ----------
Originally posted by clickclick Just tested my K3II and D FA 150-450 in 9 point AF mode, and no issues.
Thanks! I'll have to experiment more to see if I can identify what triggers the issue. The K3II is a slightly different camera with different firmware, so it may not have the same bug, but thanks for responding!
Quote: Have you double checked the focus mode switch, as well as all the other focus related switches to make sure one isn't in a partial engagement etc.?
Good point. I'll double check - although I have no problem as soon as I set the AF to centre spot.
