08-25-2008, 08:31 AM   #1
eccs19's Avatar
New lens question
I picked up this lens on the weekend.
Pentax 50mm prime F2
Pentax Lens Review Database - 50mm F2
Just wondering if there is an ideal distance from subject to test the quality of the lens. I could take a picture of a treeline that is 200 feet away, but if I'm to zoom in on those trees, at that distance, it would not be sharp. There must be an ideal / recommended distance that I could use to judge if this lens is working the way it should.
Thanks for your input.
08-25-2008, 08:42 AM   #2
Wheatfield's Avatar
QuoteOriginally posted by eccs19 Quote
10-20 feet should do the trick.
08-25-2008, 09:12 AM   #3
it's digital! try a bunch of distances
08-25-2008, 09:59 AM   #4
eccs19's Avatar
Ya, this is true. I was just curious as to where I should get best result.
QuoteOriginally posted by k100d Quote
08-25-2008, 12:09 PM   #5
Kei
I have the A version 50mm f2 and just found out its not good for focusing far away objects. Even tho I set it at infinity focus, I can tell the image is OOF without pixel peeping. I will now use it for close up and portrait…the effective 75mm FOV on my k200d seems perfect for the job.
08-25-2008, 02:11 PM   #6
Marc Sabatella's Avatar
QuoteOriginally posted by Kei Quote
Sounds like a defective lens. The lens is certainly capable of decent infinity focus, but of course, it's not the highest-resolving lens in the world, so you can't get the same kind of detail you can at closer distances. And of course, that's really the of any lens.
08-25-2008, 06:37 PM   #7
Kei
Having my first DSLR and the A 50 f2 for only 2 months, I am more inclined to believe its my problem rather than the lens' . But your words sure did open up another possibility, now I will need to find sometime to really test it out. The last time I used it for about 30 shots in pitch dark and I was in a hurry so that may be the problem.
50mm, distance, f2, k-mount, lens, pentax, pentax lens, slr lens
K-X Lens Question Lucas Troubleshooting and Beginner Help 8 06-29-2010 10:29 PM
lens question - manual lens won't fire wackymummy Troubleshooting and Beginner Help 7 05-21-2010 10:16 AM
New FA 31 lens question Mr Toad Pentax SLR Lens Discussion 9 10-05-2009 11:13 PM
FF Lens question... Jasvox Pentax SLR Lens Discussion 3 04-18-2008 02:16 AM
Newb AF lens question about lens for K10D pentaxbling Pentax SLR Lens Discussion 3 08-15-2007 05:52 AM
All times are GMT -7. The time now is 03:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
