Show Printable Version 4 Likes Search this Thread
10-21-2017, 01:06 PM - 1 Like   #1
Jome's Avatar
LBA Itching... What about a HD DA 1.4?
Hello dear Pentaxians,
Can someone tell me about the effect of the HD Pentax-DA 1.4 AW AF converter used with those lenses (and my K-3)?
Is it really (aside LBA) worth it for:
DA* 60-250?
Does it work with the FA* 85?
Also for Astro with a telescope?
Could please someone provide some picture links with those specific combinations (I have only seen 2 from the 2014 Normhead's review of the converter)?
Thank you in advance as I think i have found one at a fair price.
Kind regards.
J.
10-21-2017, 01:53 PM - 2 Likes   #2
VoiceOfReason's Avatar
It works well with the DA* 60-250
I am not sure on the FA* 85, but it works with every single AF lens I have and passes correct info whether screwdrive or not.
Yes, it works well for astro with a telescope and with a lens. PeteXL uses it. check the Astrophotography user group on here. I've used it and have been happy with the results, but I don't have any linked pics because my processing at the time sucked. You will not introduce any bad stuff in, but it will take longer to gather light due to the stop of light lost.
10-21-2017, 04:34 PM   #3
Seeker of Knowledge
aslyfox's Avatar
perhaps reviewing the " in depth review " for the item found under " Lenses " above could be helpful
here is a direct link:
Pentax-DA 1.4x AW AF Rear Converter Review - Introduction | PentaxForums.com Reviews
https://www.pentaxforums.com/reviews/pentax-da-14x-aw-af-rear-converter/operation.html
10-22-2017, 12:11 AM - 1 Like   #4
QuoteOriginally posted by Jome Quote
The HD DA 1.4 is suitable for apsc. I wouldn't recommend for full frame, although it can be used in crop mode.
I had the TC for K3 + DA300, it worked well and make a light weight 420 f5.6. I sold it when I purchased the DFA150450 and K1.
Later I purchased again a TC, used it for a while with K1 and 150-450, but had to stop down to f11 / f14 to achieve good sharpness. + heavy vignetting, so I figured I'd crop and it would be about the same.
10-22-2017, 12:32 AM   #5
Sandy Hancock's Avatar
Stimilated by this thread, I took some shots today with the FA*85 and the teleconverter on the K-1.
In full frame mode, wide open, it vignettes a little in the corners. The effect is more pronounced at infinity focus than MFD. I won't bore you with photos of the sky unless pressed.
Stopped down, the vignetting is not as noticeable, but the image quality in the corners falls off dramatically. If the image below doesn't convince you, click on it to view a larger version in Flickr.
Although the FA*85 exhibits a bit of glow wide open, when you add the teleconverter it turns into something like a Helios!
10-22-2017, 01:38 AM   #6
Jome's Avatar
Thanks for quick samples... To get an Helios-like rendering with the FA*85 and HD TC is amazing!
10-22-2017, 01:40 AM   #7
Jome's Avatar
QuoteOriginally posted by Aslyfox Quote
Pentax-DA 1.4x AW AF Rear Converter Review - Operation | PentaxForums.com Reviews
Thanks Aslyfox, I also have seen this thread:
The Pentax HD PENTAX-DA AF Rear Converter 1.4X AW (and any lens) Club - PentaxForums.com
10-22-2017, 01:49 AM   #8
Seeker of Knowledge
aslyfox's Avatar
thank you
I hadn't seen that one before
10-22-2017, 02:04 AM   #9
Jome's Avatar
OK, now I can bid on the auction. (LBA is killing me softly. But it's the last time...Seriously...for now...and so on...)
10-22-2017, 02:09 AM   #10
The teleconverter will perform perfectly on your K-3. Enjoy.
10-22-2017, 03:36 AM   #11
Jome's Avatar
Auction won! But quite pricey: 245$ including shipping (Was 75$ 3 minutes before end of auction). Is it a fair price?
10-22-2017, 03:57 AM   #12
The HD teleconverter is USD600 at B&H currently, so I'd say you did OK
10-22-2017, 04:05 AM   #13
Jome's Avatar
600$ ?
Have seen them from 410$ to 530$ New in Switzerland (with 2 years warranty)!!!
converter, hd, k-mount, lba, pentax lens, slr lens
HD 20-40 or HD 21 & HD 35 macro BarryE Pentax SLR Lens Discussion 33 09-03-2017 06:05 AM
K-3 II + HD-DFA 150-450 + HD-DA 1.4x AW intermittent focussing problems plus others tduell Pentax K-3 & K-3 II 13 04-21-2016 03:31 PM
HD DA 21mm Limited vs. HD DA 20-40mm Limited seachongo Pentax SLR Lens Discussion 10 05-09-2015 11:18 PM
Photo of the Week - I'm Itching for Spring! Adam Post Your Photos! 3 03-12-2010 01:48 PM
All times are GMT -7. The time now is 04:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
