Show Printable Version 20 Likes Search this Thread
11-04-2017, 04:40 PM   #46
photoptimist's Avatar
QuoteOriginally posted by Nicolas06 Quote
The lens may be cheap and easy to design, but the problem is the cost. Using film, each shot is quite costly. Using digital, the price of the sensor is like the one of a luxury car.
So true! So true!
And then there's the weight of the large format camera + tripod, setup time, lack of automation, 0.01 fps burst rate, etc.
On the other hand the cost of a 50 f/0.8 lens that is flawless corner-to-corner wide open is ......?
One of the issues intrinsic to the original discussion is the general lack (or cost) of extremely fast and corner-to-corner sharp lenses for smaller format cameras. A decent 50 @ f/2.0 on FF costs less and optically outperforms a 25 @ f/1.0 on M4/3.
11-04-2017, 04:51 PM - 1 Like   #47
So true! So true!
But the system that get the thinner dof out of a 50mm f/2.0 is the smaller format, not the FF. To achieve similar dof the FF would need a 100mm f/4.
It really depend then of type of framing you want, the apperture you need and what available on the system.
To get the isolation of 85mm f/1.2 for FF on cropped 645 one would need a 110mm f/1.6. Maybe it is easier to get a 85mm f/1.2 on Canon FF than getting a 110mm f/1.6 for 645...
11-04-2017, 05:13 PM   #48
QuoteOriginally posted by angerdan Quote
The FA 35mm f/2 has an 13% longer build length than the DA 50mm f/1.8, so just a small difference.
Sure, but it's still bigger rather than smaller, and slower to boot. If you wanted a 35mm f/1.25... well, just look at the various 35mm f/1.4s. And 35s still are quite moderate. Go to 28 or even 24, and things start spiralling out of control. I did find the odd vintage 35 that was at least worth using over the 18-55 kit... 28, not so much.
And the crop sensor doesn't even get a 33mm f/1.5 on the expected level if you interpolate between the two.
I think you two are saying the same, just from a different perspective.
25mm f/1.0 (M4/3) vs. 50mm f/2.0 (FF)
is entirely equivalent to
50mm f/2.0 (M4/3) vs. 100mm f/4 (FF).
The way things have been going in the last decade or two, we might still see "affordable" medium format digital cameras within our lifetime ("affordable" complete with quotes in the way that FFs are now)?
11-05-2017, 03:18 AM   #49
QuoteOriginally posted by 52mm Quote
Only because the 24, 28 and 35mm design you speak of are basically FF design and have to cope with the DSLR registration distance and mirror. The registration distance of K-mount make sense for an FF, not so much for an APSC.
The Fuji 35mm f/1.4 and 23mm f/1.4 are quite moderate in size/weight.
But if you have the same focal length and max apperture on both, this is the smaller format that will provide the less dof because of the increased magnification.
Possible, but for me MF will stay in a niche market basically because with digital FF is provide lot of quality already and few need more.
35mm, aperture, aperture and sensor, decision, depth, exposure, field, film, image, information, joe, k-mount, length, lens, lens aperture, light, max, pentax lens, performance, post, property, quality, sensor, sensors, slr lens, sums
Aperture control problems with variable aperture lenses (with aperture rings) gtxSeries Troubleshooting and Beginner Help 3 09-13-2017 01:11 PM
Picture file size, picture pixel size, resizeing picture, discussion panonski Digital Processing, Software, and Printing 11 12-01-2016 08:38 AM
Understanding perspective vs lens size vs sensor size (lens mechanics?) soycory Troubleshooting and Beginner Help 19 12-23-2014 07:40 AM
Does size (lens elements/filter size) really matter? Vantage-Point Pentax SLR Lens Discussion 11 11-03-2014 05:31 PM
Sensor Size and Pixel Size interested_observer Photographic Technique 5 02-04-2012 07:59 AM
All times are GMT -7. The time now is 08:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
