Originally posted by Jomar ...I generally prefer to take photos of stationary objects like buildings, & neon skylines. If either/both are halfway decent at star photography, that would be a bonus I'm not expecting...
I see you're new here, 3 posts. How long have you had your K-01 and 18-55? What about the 18-55 hasn't worked well for building and skylines? I'm asking because sometimes we get attracted by new gear when there are ways to use our existing gear.
For buildings, a wide aperture is not especially important even at night. You'll want to use a tripod and long exposure. Wide aperture is more important for stars and the Milky Way because the sky moves if exposure is too long. Some suggestions for architectural shots in low light: Once you're on a tripod you can stop down the lens for good sharpness, making the 18-55 usable. My night settings are RAW picture format, Manual mode, ISO 100 for low noise (or 200 or 400 if very dark to keep shutter speed within 30 seconds), and set shutter speed to however long it needs to be for a good exposure.
If you still want to upgrade your lens, IMO the 35 and 40 are too long a focal length for buildings and stars. Most of my night architecture shots are in NYC with large buildings and not much space to back up, 35mm can't fit a building in the frame. Some lenses that have given me good results for night architectural shots:
- Pentax DA 15mm f/4 Limited: A fantastic lens for night shots in crowded cities because it is very flare resistant; nearby street lights don't cause streaks and ghost images. It also has a very good "starburst" effect around bright points of light. This is one of the best Pentax lenses IMO.
- Pentax DA* 16-50 f2.8. The flexibility of zoom helps compose architectural shots. Flare and starbursts are not as good as on the DA 15 mentioned above.
- Tamron 10-24: Can go very wide for some unique shots.
None of those lenses are ideal for stars and Milky Way shots. Pinpoint sources of light aren't what most lenses are designed for. You can try any of them for the night sky, but IMO the Samyang/Rokinon/Bower 14mm f2.8 or 24mm f1.4 excel for stars. They have very low coma distortion so stars stay sharp across the entire frame, even when used at their widest apertures. ISO 1600 and 30 seconds is a good starting point for the Milky Way.
Another way to take star shots is to create star trail images. Take continuous photos for at least 30 minutes, then combine them using software. The 18-55 is an adequate lens for that.
Now, having said all that, maybe the 35 or 40 you already suggested will work okay for you if you can back up enough from the buildings.
