Originally posted by BruceBanner I'm just curious as to whether that combination will be too long a 'tunnel' and I lose too much of the 15mm shot.
If you pull out the hood, the cutouts in the corner give you an idea what the 'line of sight' from the lens needs to be. With a slim extender and step up ring, I'm sure you wouldn't have anything to worry about.
Originally posted by BruceBanner Perhaps a slim 49mm ND filter will actually fit and I just have to decide on what stop to choose.
If you like the lens, I'd definitely recommend that. This way, you can still benefit from the hood - filters usually have more trouble with flares than the lens itself, which is magic in that respect. 49mm was anyway a reasonable choice for me as it is shared with a most of the primes that I use: DA ltds, F28/2.8, DA 35/2.4, FA 77/1.8, F50/1.7, FA50/1.4, DA 100/2.8WR, M135/3.5 and Sonnar 135/3.5. What on earth made Pentax put a 52mm thread on the DA50/1.8 for no reason? I'm using it with a step-down ring in my weight-optimized prime kit. Anybody have a spare Voigtländer Apo-Lanthar 180mm/4.0 for me to complete the 49mm set
