Show Printable Version 6 Likes Search this Thread
11-02-2017, 02:00 AM - 1 Like   #16
JensE's Avatar
QuoteOriginally posted by BruceBanner Quote
I'm just curious as to whether that combination will be too long a 'tunnel' and I lose too much of the 15mm shot.
If you pull out the hood, the cutouts in the corner give you an idea what the 'line of sight' from the lens needs to be. With a slim extender and step up ring, I'm sure you wouldn't have anything to worry about.
Perhaps a slim 49mm ND filter will actually fit and I just have to decide on what stop to choose.
If you like the lens, I'd definitely recommend that. This way, you can still benefit from the hood - filters usually have more trouble with flares than the lens itself, which is magic in that respect. 49mm was anyway a reasonable choice for me as it is shared with a most of the primes that I use: DA ltds, F28/2.8, DA 35/2.4, FA 77/1.8, F50/1.7, FA50/1.4, DA 100/2.8WR, M135/3.5 and Sonnar 135/3.5. What on earth made Pentax put a 52mm thread on the DA50/1.8 for no reason? I'm using it with a step-down ring in my weight-optimized prime kit. Anybody have a spare Voigtländer Apo-Lanthar 180mm/4.0 for me to complete the 49mm set ?
11-02-2017, 02:55 AM   #17
Digitiser of Film
BigMackCam's Avatar
Bruce - for those occasions where I've wanted to use a UV filter for protection, I've found that the 49mm Hoya HMC Slim Frame fits perfectly and allows the hood to move back and forth freely without catching the felt lining. I don't know whether Hoya does ND filters in that slim frame format, but I would check them out
11-02-2017, 03:21 AM - 1 Like   #18
Paul the Sunman's Avatar
My Hoya ND8 filter fits perfectly on the DA 15!
11-02-2017, 03:21 AM   #19
acoufap's Avatar
So by using a 49mm thread adapter ring that is super slim, I could then mount my 49-52mm adapter ring and then the 52mm ND filters?
I gather this one here is not an adapter but actual UV, but it does look slim and that shouldn't get in the way of a ND filter shot right?
Going extreme with filter on DA15 have a look at my post some time ago.
11-02-2017, 12:05 PM   #20
BruceBanner's Avatar
QuoteOriginally posted by JensE Quote
I think I like the idea of the UV filter in place of the ND filter because then as grispie points out you can now put a 'normal' lens cap on instead of the screw mount.
BigMackCam, was it this one? Genuine HOYA 49mm HMC UV(C) Camera Lens Slim Frame Filter Multicoated for DSLR | eBay
It's ten bucks cheaper than my current option of trying the shops Promaster one, only issue is waiting for it to arrive...
QuoteOriginally posted by acoufap Quote
Stop it you!
11-02-2017, 12:12 PM - 1 Like   #21
Digitiser of Film
BigMackCam's Avatar
Yup, that's the one
As well as fitting nicely, I'm pleased with Hoya HMC UV filters optically. Clearly, you're better off without them if you want the very best optical performance, but these have remarkably little negative impact on IQ - even with longer telephoto lenses which tend to show up the filter's limitations...
11-02-2017, 12:23 PM   #22
Cambo's Avatar
Lens hood...
So... before I purchased this lens I read and understood it was a 49mm thread, and I also read that it took a screw lens cap... and I also read and understood that the hood is built it. What I didn't read anywhere (and I checked a good few reviews) was that said 49mm thread filters won't reach the threads :/
Just exactly how is one supposed to get filters onto the DA 15mm lens? Also... if I get a ND filter on one, am I going to be able to extend the thread?
I dunno... I just expected a Pentax lens worth $600 that is 15mm (therefore kinda Landscape specific) to take filters, especially if they make a point of saying the thread is 49mm :|
Cheers,
Bruce.
make sure the hood is pushed ALL THE WAY in...sorry to be so obvious, but you never know. Pull it all the way out and back in again. Mine sometimes sticks if it's cold.
Cheers,
Cameron
11-02-2017, 01:30 PM - 1 Like   #23
I just checked some original photographs & seems the vignet with stepup & one ND filter is hardly noticable (mind you, i use a step up ring to 58mm as i bought filters to fit my fa31).
Some photos have severe vignet, but probably i stacked a polarizer as well on those. Can't recall.
15mm, 49mm, da, da 15mm f4, filter, filters, flickr, haida, hoya, issue, k-mount, lens, pentax, pentax da 15mm, pentax lens, slr lens, thread, uv, vignet
Pentax DA 15mm F4 ED AL Limited lens - differences between old and new version Theov39 Pentax SLR Lens Discussion 22 07-11-2017 12:18 AM
For Sale - Sold: SMC PENTAX DA 15mm F4 ED AL Limited (Green Band) RockvilleBob Sold Items 10 03-31-2017 05:57 PM
For Sale - Sold: **SOLD***SMC Pentax-DA 15mm F4 ED AL Limited Luke. Sold Items 4 09-25-2016 02:54 AM
For Sale - Sold: SMC Pentax-DA 15mm F4 ED AL Limited mikeSF Sold Items 4 07-20-2016 09:54 AM
For Sale - Sold: SMC Pentax-DA 15mm F4 ED AL Limited Irish Pride Sold Items 3 02-26-2016 06:56 PM
All times are GMT -7. The time now is 08:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
