Originally posted by Helix
Thanks! I've been a lurker on here for a good while and figured this would be a decent excuse for jumping in.
And cheers for the info, it's an interesting lens. Built like a tank, in surprisingly good condition, smooth operating and does indeed produce the love/hate bubble bokeh! A funny quirk with the aperture is that when wide open, the blades don't seem to fully retract, with the tips of the blades still slightly visible at the edge.
I'm not sure how many were made, but mine has a min aperture of 16, where I've seen some photos of an otherwise identical version which goes up to 22. I wish there was more information on it, with the 50mm f/3.5 version seemingly more common (though I have no idea which was considered better).
Hi,
I have the same lens, m42 mount. See photos.
Question, does your lens have the rear aperture pin like mine? The m42 to pk Adapter does not actuate this pin when it is attached to the camera. So, it takes good pictures, but there is no aperture control. So, it is always wide open at f3.5.
Do you have the same issue?
Please advise.
Thanks.
Don
---------- Post added 01-01-18 at 09:13 AM ----------
Originally posted by BigMackCam
Definitely a good way to jump in, and glad you did
I always like to hear about lenses I'm not familiar with
Does it have the push/pull action for setting the aperture? This is a feature of the E. Ludwig Meritar, and I confess it had me a little baffled to begin with
As for the non-fully-retracting aperture blades, I suspect it's part of the design. I have a Soviet-era Orion-15 28 mm f/6 rangefinder lens that has this same quirk, to quite a noticeable extent, but it's a perfectly normal property of the lens.
If you're interested in vintage lenses and not already a member at
mflenses, I'd suggest you join them. I prefer PentaxForums for Pentax-specific and general photographic chat, but mflenses is a great place to find out information on older glass. It's been invaluable for me with some of my Soviet lenses
"Does it have the push/pull action for setting the aperture? This is a feature of the E. Ludwig Meritar, and I confess it had me a little baffled to begin with
Hi,
My Primotar 50mm f3.5 lens has an aperture pin at the rear of the lens, which, since nothing actuates it when it is mounted with an m42 to pk adapter, leaves the lens aperture wide open, unable to be closed down. Is that what you are referring to above, and, if so, what is the process to get the aperture to open and close. Depressing the pin, when the lens is not attached allows the opening and closing of the aperture.
Btw, my blades are also partially closed at fully open position.
Thanks,
Don
