Hi all. I recently succumbed to LBA and came into the possession of a nice old Sigmatel 135mm lens with a Y/S mount on it. The previous owner had a Nikon F NAI mount on it, and used it with a Micro 4/3 camera with an adapter. I was under the impression that the Y/S mount is very similar to the T-Mount, and that adapting it to M42 or K mount ( preferred ) was a simple affair.
However, after doing a bit of searching ( hopefully in the right places?? ) for information and talking with a gentleman who ( apparently ) unsuccessfully tried to adapt a similar lens, I'm a little bit worried that it might be a bit more complicated and a little less feasible than I had originally thought. I'm not overly concerned about retaining infinity focus, as the lens would be used as a portrait lens; and neither am I concerned about keeping the function of the aperture level. However, if it is as simple as purchasing one of those cheap T2/K mount adapters and swapping the plate on the back? Or do I have to find an original mount for that lens to suit K mount, or a vintage adapter that's rarer than hen's teeth?
If I've goofed, you're more than welcome to tell me; but if adapting it is indeed simple I would appreciate any information that people may be able to provide, especially if lens surgery is involved!
Thanks in advance.
