Show Printable Version 6 Likes Search this Thread
12-07-2017, 02:32 AM   #1
Your perfect 3 lens set for an MX
Firstly, let me introduce myself. I am a keen photographer of some 30 years and shoot a mix of film and digital in 35mm and MF, using both SLR and rangefinders. To date I only briefly flirted with Pentax (an SFXn) but want to now experience an MX.
So regarding lens, if you were to choose only 3 primes for the MX to cover a range of Shooting situations, balancing quality, price and size, what would they be?
Thanks
12-07-2017, 03:02 AM - 1 Like   #2
This would be my kit
SMC Pentax-M 24-35mm F3.5 (neat wide angle kit)
SMC Pentax-M 50mm F1.4 (normal with speed for indoor use when needed)
SMC Pentax-M 100mm 2.8 (lovely compact short tele with excellent IQ)
12-07-2017, 03:09 AM - 1 Like   #3
Sandy Hancock's Avatar
Quality, price and size? You can't have everything
K28/2.0
A50/1.2
A*135/1.8
12-07-2017, 03:12 AM   #4
K28/2.0
A50/1.2
A*135/1.8
A wonderful contrarian option
12-07-2017, 03:15 AM - 1 Like   #5
boriscleto's Avatar
SMC Pentax-M 28mm F/2
SMC Pentax-M 40mm F/2.8
SMC Pentax-M 120mm F/2.8
12-07-2017, 04:44 AM   #6
28/50/135. I have a Vivitar 28/2.8 I inherited from my late father in law, a Pentax A 50/2.0 likewise, and a M 135/3.5 I bought for myself. I have considered several times getting an M 50/1.4, but I have an FA 50/1.4 if I really need something that fast (and the focusing is good enough at a pinch) and a Rikenon 55/1.2 if I absolutely have to have the ultimate in speed.
(I also have the 40/2.8 Boriscleto mentioned above, but I find that more useful on my ME.)
Depending on my interests and whether I lived in a sunny climate, I might be tempted to make the fifty a macro. If not, then an investment in high-quality extension tubes with aperture coupling should be considered, if you don't have them already.
If you're having trouble finding a set of genuine coupled extension tubes, buy some really cheap, terrible secondhand extension tubes teleconverters in 1.4X, 2X and even 3X, and deglass them. This is not a difficult process, and can be done nondestructively; the optical elements unscrew from the back in most cases, though you may need a spanning wrench (or crib with a cheap set of compasses from a stationery store) to get things started.
12-07-2017, 07:13 AM   #7
baro-nite's Avatar
Two lenses I own and consider a great match for the MX are the Pentax-M 28/2.8 (older version) and Pentax-M 50/1.7. Same vintage as the MX, and both are very compact, sharp when stopped down a bit, and easy and cheap to buy. I don't have any of the M-series telephoto lenses so I'll leave that to others to recommend.
12-07-2017, 07:48 AM   #8
timw4mail's Avatar
K28/2.0
A50/1.2
A*135/1.8
Why bother getting the more expensive A 50? a K50/1.2 would suffice.
My Three:
  • K/M 28/3.5
  • K/A 50/1.2
  • K/M 135/2.8
Isn't this like a standard set of three primes? 28,50,135?
12-07-2017, 08:02 AM   #9
twilhelm's Avatar
Yes, my first set of primes was a 28,50,135 and I still have and use them with my ME.
For size, weight and cost, the M series wins out with the 28 3.5, 50 1.7 and 135 3.5.
12-07-2017, 08:03 AM   #10
Mistral's Avatar
My lens kit fot MX
My kit was:
K 18 f/3.5
M 50 f/1.4
M 100 f/2.8]
12-07-2017, 08:46 AM   #11
QuoteOriginally posted by dcshooter Quote
given the small size of the MX, you might find it a little unbalanced.
I'll second that. I have the Pentax-M 80-200 f/4.5 and find that quite awkward on the M bodies (ME, MX). (No, I don't have an MX winder, though if the OP gets one that may make handling a fair bit easier.)
OTOH the M 135/3.5 is one of the most compact primes (length and diameter-wise) of that focal length in my possession, doesn't weigh much either, and fits right into the middle of that focal range.
I know an alternative kit when zooms started getting half-decent optically was 28/50/80-200, but OP is looking for primes, and a 200mm prime lens next to a 50 might be just a little bit too much gap between the focal lengths. And I would worry that 100mm (as suggested by Mistral) wasn't nearly quite enough.
12-07-2017, 09:03 AM   #12
twilhelm's Avatar
There’s a lot of agreement here on the primes, but possibly my favorite zoom for my ME is the 24-50. Perfect size and great image quality for film.
12-07-2017, 09:54 AM   #13
Otis Memorial Pentaxian
This is the kit I purchased in 1982 for my similarly-sized Ricoh XR-7:
  • Pentax-M 50/1.7
  • Tamron 28/2.5 (02B)
  • Tamron 70-150/3.5 (20A)
The above were chosen for the combination of compactness and performance and I still own and use all three. The kit of all three plus PK adapter can be had for about $80 USD on today's market. My cost in 1982 was considerably more. The photo below was taken a few weeks ago with the Tamron zoom on my K-3.
Pentax K-3, Tamron 70-150/3.5 (20A)
Addendum: If all must be primes, I would slip in a Vivitar 135/2.8 to replace the zoom. Get the 5-element Komine-made version (serial #28xxxxxxxxxx) with 8 aperture blades. I know...Vivitar sounds soooo pedestrian, but it is pretty hard to build a bad 135mm. Performance is on a par with the M 135/3.5 and the extra 2/3 stop maximum aperture helps with focusing. Price would be about the same. Changed my mind. The Komine-made lens is rather rare in K-mount and my favorable impression is of the 5-element version...even rarer in K-mount.
12-07-2017, 10:08 AM   #14
If you want more tele range, the A 70-210mm is also a nice affordable option.
It is also a strong performer. It is a little heavy on the small body, but still well-balanced. I think I paid $30 USD for mine this last Spring.
BTW...I strongly agree with the recommendation of the M 50/1.7 over the M 50/1.4.
12-07-2017, 10:12 AM   #15
monochrome's Avatar
M28/3.5
M50/1.4
M85/2
optional / substitute
M24~35//3.5
M100/2.8
M135/3.5
M150/3.5*
* less we’ll known ‘sleeper’ lens.
135mm, 50mm, f2, iq, k-mount, kiron, kit, lens, lenses, mx, pentax lens, pentax-m, pentax-m 24-35mm f3.5, slr lens, smc, smc pentax-m 24-35mm, tele
Perfect Future Travel Lens Set? Loren E Pentax SLR Lens Discussion 20 01-02-2011 06:44 PM
The Perfect Set of MF Lenses Frogfish Pentax SLR Lens Discussion 41 07-10-2010 12:29 PM
Perfect subject with perfect light codiac2600 Post Your Photos! 13 07-20-2008 06:35 AM
All times are GMT -7. The time now is 10:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
