Originally posted by nocturnal Don't use UWA lenses for aurorae as they are less sensitive than the human eye.
Aurorae are not a small and dark deep-space phenomenon, for which this is important. As stated previously, it really depends on your desired field of view. The angle of the aurora structures in turn varies with how close to or how far under the oval you will be. See e.g.
Homepage | NOAA / NWS Space Weather Prediction Center. I would expect Yukon right below the oval most of the time, even more than Lofoten. This mean you'd ideally have something starting really wide for structures taking up most of the sky, up to maybe 'normal' perspective, roughly 35mm on a K-5.
See
Pentax DA 35mm f/2.4 on a k1? and for examples from Lofoten at the extremes of focal lengths which I found useful on a recent trip. Taken on a K-1, so you have to divide focal length by a factor of 1.5 to get the focal length for the same field-of-view on a K-5. My daughter shot side-by-side with me with less 'fast' zooms using a K-50 with some great results at f/3.5 to f/5.6 (using mostly the 8-16mm Sigma, the DA 18-135mm, an FA50/1.7), even though with somewhat longer exposure times, which means fast-moving structures appear a little softer.
For your extra budget, one of the fast (APS-C) Samyang/Rokinon ultra-wides (esp. the 10mm) may get you less noise - if you can find them at that price. The inexpensive 8mm fisheye is unfortunately not so great fully open, even though I have shot some decent night skies using it on my K-5 at f/4.5, none posted though.
