It depends on the sensor format, what you like to photograph, what field of view you like to work with best, and what other lenses you own.
Your profile shows you have a K-5IIs, so I assume your question applies to APS-C format. Given that - and assuming you're happy with the stop-down metering - my choice would be to keep the K 35/2. I like working with 35mm lenses on APS-C... not surprising, really, since the field of view is equivalent to a 50mm lens on full-frame. It's a great general-purpose field of view for many types of photography. Extremely versatile, and especially so with the relatively-fast f/2 aperture.
I'd probably lose the K 24/2.8 first, but that's very much a personal thing, as I rarely go below 28mm on my APS-C cameras. Then again, you own the FA31 Ltd, so you might be better off getting rid of the A 28/2 first, since the field of view and max aperture aren't significantly different. You have that field of view more or less covered
