Originally posted by normhead The 16-85 is the current "standard" for consumer lenses on APS-c.
The 28-105 is the current standard as an FF lens.
But the 16-85 is wider on APS-c than 28-105 is on FF. As they are both the most recent in their class, you wouldn't think there'd be a lot of difference optically. But since they are designed for different formats, they really aren't competitors. In FF numbers the 16-85 is 24 to 128, so a more useful range on the 16-85 but then, that's part of the APS0c advantage.
Thanks, Norm, agree, both lenses are designed for APS-C and FF camera respectively as general purpose walk around lens. While the DA 16-85 lens have heavy vignetting issue (set to FF), the DFA 28-105 can be used on the k-3 with no apparent limitations. And it is also lighter and seems to be a tad faster at given focal lengths.
---------- Post added 12-20-2017 at 09:40 PM ----------
Originally posted by C_Jones The 16-85 lens is excellent. I have one on my K-3II. I like the barrel ring color.
I agree, I like the red ring on the 16-85 lens, looks sharp. It has a smooth focusing feel and I also like the tone color coming out of it. This will be my go-to lens along with my DA 20-40 ltd for my k-3.
---------- Post added 12-20-2017 at 09:43 PM ----------
Originally posted by Adam Nobody really knows why some of the HD lenses have red rings and others don't. The first HD lenses to be launched got red rings (compared to their predecessors' green rings), but then Pentax started making HD lenses with green rings and stopped launching the red rings. IMO, both types look nice
The 16-85mm doesn't cover FF, with or without the baffle.
Thanks, Adam, I agree, either red or green ring looks nice on the new DC motor lens. Good to know that the 16-85 is designed straightly for APS-C with or without the baffle on the back of the lens. However, I found out that although the DA 20-40 ltd was designed for APS-C, I use it on my k-1 without much trouble in most cases.
---------- Post added 12-20-2017 at 09:45 PM ----------
Originally posted by blucoala I think the red ring was use to signify HD coating when it was introduced. New lenses don't have red rings now that HD coating has become standard.
Agree, when the DA 55-300 was updated with HD coating, it has a red ring; now all new lenses have the HD coatings so back to the original lens ring color scheme.
---------- Post added 12-20-2017 at 09:48 PM ----------
Originally posted by mikesbike The DA 16-85mm has a greater zoom range than does a 28-105mm lens, hence the greater cost factor and larger filter size, all other quality issues being similar. Evidently, you've done the right thing in getting great walk around zoom lenses for both cameras!
Thanks, I intend to use these two lenses as default for the k-1 and k-3. As for the back up or second lens, I will take the DA 20-40 ltd, FA 31, 43 or 77 depending on the needs for the k-1, DA* 16-50 and 50-135 for the k-3.
---------- Post added 12-20-2017 at 09:50 PM ----------
Originally posted by pathdoc The DFA28-105 may nominally be a green-ring lens, but it seems to have stolen a sprinkle of Pixie Dust. I was considering one, but the number of things my kids are in that require photographs in relatively poor light at a distance is pushing me toward the D-FA* 70-200 first. In the meantime, the 100WR is my go-to foul weather lens, as it almost always has enough FOV for most outdoor shots I want, and when the passing parade passes close, it gives me the close-up details if I want them.
Thanks for your comments, I agree, the DFA 28-105 will likely my choice for outdoor shots, for indoors, the DA 20-40 gets the call for now with either k-1 or k-3. For indoor shots, I also use flash when I see the need to do it, so not a big problem.
---------- Post added 12-20-2017 at 09:53 PM ----------
Originally posted by northcoastgreg These two lenses have different goals. The point of the DFA 28-105 is to provide a relatively inexpensive option for FF that, for the most part, can take advantage of the 36 mp sensor of the K-1. To meet the $500 price point, the lens gives up some range, starting at 28mm and ending at 105mm. Since the lens is produced to try to entice people to buy the K-1, it's sold at narrower margins. With the DA 16-85, you have a different situation. Quite a few relatively inexpensive options already exist on the APS-C side of things (DA 18-55, DA 18-50, DA 18-135, DA 17-70, DA 18-270), the DA 16-85 was not designed to be one of the less expensive options on APS-C, but was given greater range to fit into a missing niche (essentially a slow aperture zoom lens that starts at 16mm, perfect for landscape and travel photography). The longer range, particularly on the longer end, increases cost and makes it more of a specialty lens, which allows it to be sold at higher margins.
Yep, absolutely agree, the higher range 16-85 zoom probably has more element and harder to design, hence the higher cost expected. Although some Can-nikon friends seem to think that FX lenses should always costs more than DX lenses.
