Originally posted by halimj7 Bismillah
I have the DA*200mm f2.8 and a KP but want more reach. What is the advantage to getting a 1.4x teleconverter? Can I reproduce the same or better IQ by cropping in post?
Also can I crop again effectively after using a teleconverter on a crop sensor? Thanks.
Assuming you use a good quality teleconverter, you are changing the focal length of the glass in front of your camera's sensor from 200mm to 280mm. This gives you greater magnification although the downside is you will lose some light.
By cropping a non-TC image (200mm) to the same image size as a TC image (280mm) you will be losing resolution. Will that be noticeable ? Depends on the quality of the TC (a poor quality one would even give you a worse image). A good quality TC should give you a better image quality, but the KP has a good sensor to start with and without knowing what you want to do with your images (view online or print) I would suggest it may be marginal.
Of course you can crop again, and this is where the TC may be advantageous. If you find you crop a lot you should always get a better result from cropping less with the TC (a good quality one) than cropping more without it.
