I have a Peleng 8mm, a fisheye with circular image made in Belarus (former soviet lens maker Belomo).
The example I have is M42, but I decided to order the Pentax flange (similar but not compatible with T mount). 20 USD + 5 for shipment.
Tried a couple of shots with my K-1...then it started raining
It is a classic fisheye, like the old Nikon i guess. IQ is not great if I examine the image at 100%, but it's better than I expected. Other more conventional optics have less definition and worse contrast.
Tried defishing, with PTlens is better to crop the picture beforehand, other way the result is not very satisfying.
Given the extreme coverage, it's definitely a different animal, quite far from my Samyang 14mm rectilinear.
It's not a toy lens, and from what I understand it's a lot better than old designs like the T mount fisheye sold long ago as Vemar (or other brand names).
It has one more element than the Sammy 8mm, and I'm very surprised by the very limited fringing, that usually plagues this kind of lenses.
I'd be interested in Hemi Fisheye, that should defish circular fisheye's pictures in a more efficient way.
Unfortunately as far as I understand the activation is specific to the software platform, which means that the same serial can't be used on both Mac and Windows. Other way I could share it with a friend who works with Windows...
I'd be interested in the personal experience of other fellows using the Peleng on FF.
How is your example? Soviet lenses have a certain variability...
Do you just crop the circular image, or also defish?
Does your lens have a certain amount of play, in the mount? Mine was OK with the M42 flange but the PK mount moves a little.
Cheers
Paolo
