Originally posted by BigMackCam Optically they're the same, based on everything I've read.
Originally posted by Aslyfox From the in depth review, it appears the optics are the same
The XS was marketed as having rounded blades, as was the HD version. The SMC version was not marketed as such, though I seem to remember a forum user claiming that there is no difference in bokeh between SMC and XS version. HD features newer coatings and the PF review claims it has even better contrast, flare resistance than the SMC. My XS is a little prone to fringing wide open, but it is quite sharp and good, even without lens hood, if you go above f3.2. I usually shoot at f5.6-f8 with it, but my recent f2.8 photos with it were really sharp with nice creamy bokeh.
The XS lacks QS, DoF scales, hood, and it has almost useless 27mm filter ring (though, you can still find some filters for this size, at really low costs). XS has plastic body, but the mount is metal (unlike DA 35mm f2.4 or the DA L kit lenses)
Some users claimed the XS is optically different because it has been recessed further into the body to make it even thinner. Pretty sure it is/was the thinnest DSLR lens produced (ignoring "pinhole" lenses, because these are not really lenses). The DXo reviews give really odd measurements, and sometimes show the XS as the sharpest one. I suspect this is due to either copy variation or sloppy test work. I would assume the HD is optically the best, even if the differences are imperceptible in most light conditions. I have not seen a direct comparison of a large sample of all three of these versions which would clear everything up. But I doubt anyone owns all three, because they are so similar.
Bottom line is, we don't actually know. The Pentax engineers are the only ones that know what exactly is different between versions. Coatings, optical tweaks, aperture blades, inner barrel.. lots of factors to consider and we simply do not have the info. Would I buy the HD? No, because I got a nice XS with the K-01. But I am sure the SMC and HD versions are optically so similar to the XS that I could safely recommend whichever one. Comes down to features and budget. If you are planning on shooting in extremely difficult light conditions, the HD might make sense. If you are planning on doing starburst/diffraction spike photography, the SMC might be best. If you want a super light travel prime, get the XS.
