Originally posted by toukan So now the front face of the adapter is facing the what would be the camera body. I have tried turning it, but it only goes as far as the spring, but no further.
Is the adapter stuck on the lens or is it engaged with the body? I fear you are describing the latter, but since the lens is SMC it is possible that it is hung up on the small interlock pin on the lens mount face. Look carefully at the edges of the mount tangs for this small pin. When you find it, press it down and slide the A/M switch to the A (Auto) position. That should retract the pin almost completely to allow the adapter to rotate off. If the retraction is not enough, press the pin fully down and carefully rotate the adapter counter-clockwise with the pin sliding underneath. The rotation should lift the adapter clear of the pin.
P.S. I did a dry run of this solution on my S-M-C 28/3.5 just before posting. Be very careful and FORCE NOTHING. You don't want to damage the interlock mechanism on the lens.
