01-02-2018, 01:05 AM   #1
Sigma 50-500mm OS lens Optical Stabilization on / off when using Monopod
Hello,
I have the Sigma 50-500mm HSM OS lens and shooting with it hand held in last two years, I understand just use the lens' optical stabilization and turn off my camera (k5/k1) stabilization to get the best result. It's a big and heavy lens so I put it on a Monopod first time last week and go out to take some photo. I use the same setting as what I did when hand held, to my surprise, near 60% of the photos were burr and it's almost double as what I got when hand held.
So I'm thinking should I also turn off the optical stabilization on the lens (also on the camera) when using the Monopod ( just like the Tripod) ? Anyone have experience on this ? thanks.
Michael
01-02-2018, 01:54 AM   #2
Unstabilised lenses work fine,so why have it on?...
01-02-2018, 02:01 AM   #3
Paul the Sunman's Avatar
What FL and shutter speed were you using? Unless you are very good with the monopod, I'd keep at least one of OS and SR on.
01-02-2018, 05:14 AM   #4
I would compare the performance of the in-lens OS to the in-camera SR. It's possible that the SR would be better, or that the OS is malfunctioning. You should be fine to use either one, but not both.
If there is not much sway in the monopod, you should be fine without any SR.
01-02-2018, 03:43 PM   #5
I used a friends 50-500 with a monopod and OS turned on and i got excellent results so i'm not sure why yours would be different. I have noticed that when using the monopod i would slightly move front to back when trying to hold still and with a narrow depth of field that often accompanies such a long focal length it would be easy to get shots slightly out of focus. Maybe a better technique would help? I try to find something to brace against but that isn't always possible.
01-02-2018, 04:37 PM   #6
QuoteOriginally posted by bschriver11 Quote
I just gave mine a test...works fine with On or Off....Both on a Monopod and handheld.
Not that i'll use this lens either way for a long period...3kgs gets a tad HEAVY!
---------- Post added 01-03-18 at 10:39 AM ----------
HA HA HA, theres sway!...even with the 3 pronged foot.
01-02-2018, 05:49 PM   #7
I think I need to practise more on using the monopod as I just use it less than 5 times, and with some shorter lens. Yes, I find it is very easy "swing" with the Sigma 50-500 even I seem to hold the Monopod firmly (or it swing when I press the shutter), and now I believe this is the main cause of the photo burr ! Thanks all.
50-500mm os lens, camera, hand, k-mount, lens, monopod, pentax lens, photography, sigma, sigma 50-500mm os, slr lens, stabilization
Optical stabilization jonhock Pentax SLR Lens Discussion 9 10-23-2015 10:11 AM
Lens Stabilization VS Camera Stabilization philbaum Non-Pentax Cameras: Canon, Nikon, etc. 17 10-14-2015 12:38 PM
Need lens hood for Sigma 170-500mm...same as 50-500mm and 150-500mm? Help please! Edgar_in_Indy Pentax SLR Lens Discussion 10 09-09-2011 05:32 AM
Sony and Pentax to get optical stabilization, courtesy of Sigma? ftpaddict Pentax SLR Lens Discussion 12 03-09-2009 02:21 AM
In-body stabilization + lens stabilization ntx Troubleshooting and Beginner Help 14 02-24-2009 05:24 PM
All times are GMT -7. The time now is 11:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
