Originally posted by Rondec Maybe so. If they are going to do a 20mm full frame prime, I would prefer one a bit wider -- closer to 20mm than to 30mm. I would be fine with slower aperture -- f2.8 or even f4, as long as it was pretty sharp wide open.
Sure, my A20/2.8 is a wonderful lens around daybreak and dusk, but my K20/4 is also very good, and probably less expensive to update. However (with no knowledge of optical engineering) I have to wonder how much slide rule lens design information can be transferred to CAD.
One assumes Ricoh has at least
some embedded optical assumptions from which to start; but are those assumptions even
marginally useful when taking into account modern glass properties, lens blank machining tools, manufacturing assembly processes and component availability?
Maybe they have to start from scratch anyway.
