01-14-2018, 05:07 AM   #1
DA* 50-135 loose focus ring
Hey folks, looks like my troubles with new gear continues...
I've just received brand new 50-135 and it has loose focus ring. This loosness feel is more noticable to the one end of infinity than another. When I rotate the focus ring and then rotate it to opposite direction, the inside ring in the focus window catches up in 0.25-0.30mm and in that zone when it's more noticable I can hear a clacking sound if I rotate it fast enough. Other than that, focusing works well both in MF and AF but it's somehow annoys me and forces me to think do I have to send it back?
01-14-2018, 09:32 AM   #2
Lev
nobody?
01-14-2018, 10:10 AM   #3
QuoteOriginally posted by Lev Quote
If there are any weird sounds coming from a new lens, I would definitely exchange it. The focusing is supposed to be smooth and consistent.
01-14-2018, 10:17 AM   #4
35mmfilmfan's Avatar
nobody?
Bit eager, aren't you ? Not everyone is either awake / on line at this time of day. That said, if I got it, I would certainly get it investigated - when you say new, do you mean brand new from a dealer, or just new to you ?
01-14-2018, 12:56 PM   #5
Lev
QuoteOriginally posted by 35mmfilmfan Quote
man I don't want to be rude or something, not that kind of guy and I didn't know my last single question could hurt someone but if you think this is somehow negative post then my apologies personally to you
---------- Post added 01-14-18 at 01:00 PM ----------
No Adam, it's not a weird sound, I think this sound is coming from gears when they engage. Focusing itself is very smooth in both directions. I'm just concerned about this "dead zone" between rotations, how much is normal and should it be there at all?
01-14-2018, 01:09 PM   #6
I don't have a 50-135mm any more so I can't test it, but I don't recall there being any slack in the focus ring. The only thing is that if you turn it past infinity or minimum, it should just sit there and do nothing. Can you post a video maybe?
01-14-2018, 01:59 PM   #7
Lev
not a problem, it stays there, ok I'll prepare and post a video
01-14-2018, 03:27 PM   #8
Lev
here's video:
sorry for background!
01-15-2018, 03:47 AM   #9
@Lev - sorry if you took my comment the wrong way, it was meant to be a gentle humorous aside, not a criticism of a negative post. Part of the trouble with just text - no context ! No offence intended, no offence taken. Good luck with getting it fixed / replaced.
01-15-2018, 04:13 AM   #10
Lev
It's absolutely ok!
So you're in those people who thinks that it should be replaced?
01-15-2018, 04:17 AM   #11
It's absolutely ok!
I can see no reason why not - unless purchased at a discount with any problems clearly indicated, it should work as specified. It appears that yours does not.
01-15-2018, 04:25 AM   #12
Lev
yes but how do I know that I'll get another copy with same effect? besides, it takes almost a month to send it back and get replacement, pay additional fee for transportation etc etc.... If I know for sure that it is a defect I'll send it back right now but I'm not sure
01-15-2018, 10:23 AM   #13
My 50-135 is many years old. It is similar to yours. It makes the same noises and has a little bit of play before the clutch engages. It is hard to tell, but I think mine might have slightly less play than yours.
01-15-2018, 10:27 AM   #14
Lev
thanks, ok well, looks like I'm not alone but can somebody tell if this is normal and within specifications of the lens?
01-16-2018, 05:56 PM   #15
here's video:
It also looks normal to me.
focus, k-mount, noticable, pentax lens, post, slr lens, sound
A28 2.8mm Focus ring is really loose bass3587 Pentax SLR Lens Discussion 6 06-07-2017 05:55 PM
Pentax MG - Porthole Glass on viewfinder is loose + loose piece blocking view. Help? Benbrackett Pentax Film SLR Discussion 2 04-28-2017 01:00 PM
Cosina 55mm f/1.2 Loose focus ring serothis Troubleshooting and Beginner Help 12 01-06-2017 09:35 PM
DA L 18-55mm manual focus ring too loose jamesv93 Pentax SLR Lens Discussion 2 11-28-2009 12:03 AM
All times are GMT -7. The time now is 02:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
