01-23-2018, 08:17 PM   #16
The simplest solution is take your DFA 24-70mm and supplement it with a DA HD 55-300mm WR. Doesn't have to be the PLM version, the older one is fine optically, and gives you a true 300mm even at closer distances. It is also well-built, and apparently is usable for FF. I really like mine. Even better, if you can also manage having a compact APS-C body along as well, you could have the 55-300mm on it and the 24-70mm on your K-1, so you could grab virtually any shot that comes up without having to change lenses. If you are with a companion, that might help in this case.
01-24-2018, 06:11 AM   #17
bdery's Avatar
DA*60-250 this needs modified a bit but when that is done it works just fine on FF. I modded mine and it is what I use for tele-zoom. Not the fastest focusing, but excellent images
F 70-210 f/4-5.6 an old standby. Very small very fast to focus and decent image quality. I still pack it occasionally when I want to travel light.
PS. I am considering selling the FA 100-300, if interested PM me and we can talk.
These three lenses are exactly what I would have recommended. I'd look into it. For the 100-300, consider only the F4.7 version, the F4.5 is not as good.
01-24-2018, 06:08 PM   #18
Scorpio71GR's Avatar
The DFA 28-105 is one of the few lenses that just continues to impress me. It always goes with me with the K-1. That and a DA*200 would about be your best FF lightweight kit in my opinion.
01-27-2018, 07:47 AM   #19
mgvh's Avatar
I'm guessing the DFA 28-105 would be best, but when I can afford a K-1, for travelling around, I've held on to my Tamron 24-135. It won't match up in quality to the 28-105, but it's both wider and longer, so it's handier for travel. There are still copies out there and available.
01-27-2018, 08:06 AM   #20
Iíd take the 14, a 28-105, and one of the 70-300s.
Thatís a good compromise of good and light ...
- Eric
frame, frame travel, image, k-mount, lens, lenses, models, options, pentax, pentax lens, quality, slr lens, weather
Some questions about buying sony full frame + adapters + pentax full frame lens jhlxxx Pentax Full Frame 8 06-14-2017 05:13 PM
K-1 So What Is Full Frame Going To Provide Over A Crop Frame DSLR MRCDH Pentax Full Frame 312 03-22-2016 01:21 PM
From Full-Frame Sony... to Pentax... to Full-Frame Canon Mr_Canuck Non-Pentax Cameras: Canon, Nikon, etc. 42 01-21-2014 12:50 AM
Full frame or no full frame.... Deedee Pentax K-3 14 10-08-2013 05:39 AM
Full Frame Full Frame vanchaz2002 Pentax DSLR Discussion 30 12-11-2008 07:09 AM
All times are GMT -7. The time now is 04:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
