Originally posted by Adam Are you are re-focusing after you zoom, right?
Adam, of course I do. I was wondering why allmost all my photos are out of focus. Sadly but fact that even when I focus it somehow, pictures from my 16-85 look better in tele range. Do you think that the AF fine adjustment may differ from wide to tele range and that this is normal?
Does anybody have idea what these vertical lines mean in focus chart I have posted? or that strange out of focus area in corner of the first picture?
---------- Post added 01-24-18 at 11:45 AM ----------
Originally posted by BarryE Isn't a variation between front and back focus across a zoom lens' range usual ? It has been on all the zooms I've ever owned - some more than others. Obviously, if it's extreme then there may be a problem, but with a complex range of optical parameters to handle, there's always going to be compromises. I've found that I've set my zooms up to be better on the end that I tend to use most, then ease off a little towards the required adjustment at the other end. So never is it perfect, but it's better where I tend to need it most. They I try to remember this. Isn't this normal ? I've discussed this with users of other brands and folk in the trade, and it seems it's an accepted compromise, but most users just don't notice the problem.
On my K-3s most of my lenses (zoom and primes) are adjusted between +5 and +7 (interestingly both K-3s are 1identical). My 50-150 varied by about +3 as I recall, but my 16-50 was more like +5. Some field curvature may be involved in the latter. My K-1 is completely different as I've left all my FF lenses at 0, a zoom too - been lucky.
Also, I set my AFs up by measuring a target at about 2 to 3 m, as I found measuring at shorter distances gave inconsistent and less helpful results for my usage. Any close-up work I tend to double check the focus anyway and for long distances the focus becomes less relevant.
Well, at 50mm I have to set it to +3 or +4 to make it just acceptable, not great, this way the focus point jus enters area in focus but if I want it to be great I have to set it to +10! You might think ok, let it be like that, but now at 135 you're completely out of focus
