Originally posted by Na Horuk Many m42 lenses will not screw in perfectly to the correct degree (slight misalignment). Usually there is enough tolerance to still get infinity focus.
There is a misconception regarding the "misalignment". Having the focus index mark at "12:00" is sort of nice, but has nothing to do with infinity focus. As with all other mount systems, the flange focal distance is established by...ummm....the distance from the focal plane to the face of the
body flange. Infinity focus is relative to that distance, which should also be the distance from the lens flange to the focal point when properly mounted. With screw mounts (M36, M39, M42 or whatever) The lens should stop when its face is snug on the opposing flange and not before. If that happens anywhere other than with the index mark at 12:00, it means nothing more than the thread lead-in being at a different point than on a lens that might line up.
I just did a quick survey of the eight thread-mount bodies on my shelf showed and none with the mark at 12:00 for the lenses mounted. All except one of my Spotmatics and the Canon P has the manufacturer-brand lens mounted. I have a few lenses on the shelf that do line up, but only when used with the genuine Pentax M42 adapter and then not with all three of my adapters. Again, flange focal distance with a proper adapter is made by the lens mount face snugging up to the body mount flange. All of my M42 lenses attain infinity focus on all my M42 and K-mount bodies. The same is true for all of my M39 (LTM) on my LTM bodies and on the Bessa R3M.
