04-27-2012, 09:16 AM   #151
Damnit, why did I check out this thread!!!!!!!!!!!
04-27-2012, 06:17 PM   #152
Picked up a ZK100/2 from forum member Andi today. Here's a first sample, handheld, on extension tubes:
05-15-2012, 01:04 PM   #153
Piotr's Avatar
Distagon 28/2
Pentax K-5 ,Carl Zeiss Distagon T* 2/28 ZK 1/60s f/9.0 at 28.0mm iso80
Pentax K-5 ,Carl Zeiss Distagon T* 2/28 ZK 1/320s f/8.0 at 28.0mm iso80
Pentax K-5 ,Carl Zeiss Distagon T* 2/28 ZK 1/250s f/8.0 at 28.0mm iso80
05-16-2012, 08:42 AM   #154
21, 2/25, and the macros are really worth considering. All other Zeiss lenses are just interesting because Pentax does not match the specs in their line up.
The SL-II series from Voigtländer stopped in house competition of the 125 macro to the 100 Macro Planar - too bad. With the Zeiss line-up expanding, I am wondering what Voigtländer has to show at photokina - SL-III?
The 1.8/135 Zeiss for Sony would be an interesting addition in ZK mount.
10-04-2012, 01:03 PM   #155
i own...
the following ZK lenses:
  • 18 f3.5
  • 50 f2 makro- awesome wide open!!
  • 85 f1.4- monstruous sharpness and resolution
  • and i would like to get the 100mm makro.. but hard to find!
thats it!
10-06-2012, 07:52 AM   #156
My ZK friends
Here's one of the first images of my ZK85 wide open at 1.4 - yeah, she sat still. The flower was with the ZK35 at f2.8. All are straight from the camera (*ist DS).
While the 35mm is my most used lens now, I am looking forward to exploring the use of the newly acquired 85.
PENTAX *ist DS  Photo
10-07-2012, 06:57 PM   #157
jpzk's Avatar
QuoteOriginally posted by subidoc Quote
I have the ZK 85/1.4 and I have a horrible time with it because of the focus shift inherent with this lens.
How did you manage to get a good shot at F1.4?
Did you have to fire 1000 before getting a good one?
JP
10-07-2012, 11:29 PM   #158
QuoteOriginally posted by jpzk Quote
Focus shift shouldn't be an issue
when you're focusing and exposing
at the same aperture.
10-08-2012, 06:12 AM   #159
QuoteOriginally posted by lytrytyr Quote
I am not sure what you mean by focus shift in this case... Of note, I did not have any problems focusing with this lens at f/1.4. The reason I have this is to shoot at this aperture. I really don't do stop down focussing for the reasons I have heard in that the focus plan shifts. I presume this is what is called focus shift, but I may be wrong.
Using ZK lenses is quite an experience.... a learning one in that they seem a little different, just can't articulate it clearly, but just seem a little different. I am seeing little of the 35/f2 in this forum, and wonder if I should have gotten the 24 or 28mm instead. It never occured to me to explore the wider world, but I guess I should be on the lookout. The 35/f2 seems to live on the camera most of the time, and I shoot wide open almost all the time.
10-08-2012, 06:54 AM   #160
jeffshaddix's Avatar
I've got the 35/2 - it's as close to perfect as they come. The resolution and rendering is superb. It's sharper wide-open than the FA35 and most 35/1.4@f/2 (including Zeiss' 35/1.4 IIRC). Here's a recent snap of mine:
Zeiss 35/2 @ f/2
10-08-2012, 07:28 AM   #161
I am not sure what you mean by focus shift in this case. Of note, I did not have any problems focusing with this lens at f/1.4. The reason I have this is to shoot at this aperture. I really don't do stop down focussing for the reasons I have heard in that the focus plan shifts. I presume this is what is called focus shift.
Yes, that is correct.
I have both the ZK 25/2.8 and ZK 35/2, and enjoy them both.
The ZK 35/2 is more straightforward, while the ZK 25/2.8 is quirkier.
The Zeiss shop still offers a ZK 25 and 28:
https://photo-shop.zeiss.com/en/Categories/Objektive/ZK
but they're getting hard to find now.
10-08-2012, 10:45 AM   #162
What are you trying to do to me? Ruin me financially?? Now you have me looking.... again!
PS: what makes the ZK25 quirkier?
10-08-2012, 12:40 PM   #163
The close focusing distance, 17cm from the sensor,
and the rather strong field curvature.
So despite the short MFD,
it's by no means a flat field macro lens.
However, the field curvature can be used to advantage,
either to throw the edges out of focus,
or to match a subject where the center
is further away than the edges,
like the sample I posted earlier in this thread,
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/36041-zeiss-zk...ml#post1901981
10-08-2012, 12:43 PM   #164
jpzk's Avatar
Pardon my ignorance, but what do you mean ??
I did buy this lens in order to shoot wide open at f1.4, so I use it that way: wid open, no stopping down.
JP
10-08-2012, 12:57 PM   #165
Pardon my ignorance, but what do you mean?
"Focus shift" as the way spherical aberrations
make the point of sharpest focus change
as you go down a stop or two from fully open,
even though the focus ring doesn't move.
That means that if the image looks sharp
(say on live view) at f/1.4,
it will no longer be sharp exposing at f/2 or f/2.8
unless you move the focus ring
a tad closer to the minimum focus distance.
Photozone has a good display of the effect on
Zeiss Planar T* 85mm f/1.4 ZF (ZE) (on Canon EOS) - Lab Test / Review - Analysis
. . . try and "Move the mouse cursor over the f-stop marks"
cosina, k-mount, lenses, line, pentax, pentax lens, pics, slr lens, zeiss, zf, zk
Voigtländer LBA - post your pics, notes and thoughts. thePiRaTE!! Lens Clubs 949 11-04-2017 04:50 PM
A few Zeiss Distagon T* 2,8/25 ZK shots (3 pics) tcom Post Your Photos! 3 06-13-2009 11:05 PM
LBA: first pics with Zeiss 25/2.8 tcom Post Your Photos! 5 06-12-2009 01:07 PM
Thoughts on taking pics of kids at the pool? AlphaGAK20D Photographic Technique 25 06-08-2009 10:26 PM
Voigtlander 125 vs Zeiss 100 (6 pics) tcom Pentax SLR Lens Discussion 7 08-18-2008 02:42 AM
All times are GMT -7. The time now is 01:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
