Originally posted by pentageek 11mm, as far as I know does not accept filters.
Originally posted by TerryL Just looked at my 11mm, and you are correct. It doesn't take a filter.
G'day Guys,
My apologies for butting into your conversation but I wanted to clarify a few things regarding filters on the Irix 11mm.
Firstly, to consider a screw in filter thread on the front not being useful due to the shape of the front lens element is correct, there's no option there to adopt a previously common practice of adding a UV or similar cheaper filter to reduce the amount of cleaning the front lens element will need. Having agreed with this though, I need to point out that there are filter options for the Irix 11mm.
Check out the Irix webpage, they have a gelatin filter mount near the rear lens element on the 11mm. So certain types of filters can be added to the Irix 11mm, an example of one set is here:
Aurora-Aperture PowerND IR Filter Kit for Select Irix PND-IR-KIT
Secondly, there's large filter mounting systems that have become more common of late due to the Nikon 14-24, Samyang 14mm and the Tamron/Pentax 15-30 among other lenses. These ultra wide lenses use a 150mm or 180mm square filter bracket attached to a mount that's secured to the body of the lens. An example for the Irix 11mm can be found here:
NiSi 180mm Filter Holder For Irix 11mm f/4 - NiSi Filters Australia (NOTE: Oz site with Oz prices)
So yes it is correct that the normal screw in filters can't be used, however filter options are there for the Irix 11mm. However, the biggest drawback to the 180mm filter system will be price, and whilst I hear that the Nisi filters are good quality I've no experience with them and I suggest you be sitting down before you look at the prices. So far they seem to have the only option out there as when looking at the other filter makers with 150mm systems (Lee, Haida, Fotodiox) none identified a mounting bracket for the Irix 11mm.
On one of the other issues raised about the Irix, that being the markings not glowing in a manner that's completely useful I'd just like to remind you that the K-1 is the only camera that has external lights to help with night shooting, one of which is just above the lens mount, so that's got to be kinda useful right?
Hooroo, hope the above info was of use.
Tas
