Originally posted by clackers I've actually ended up with all three, Donovan.
For me, the DFA is the smallest and WR - just a 49mm filter - with the best build.
You can't go wrong with IQ from any of them. This is the beauty of macro lenses.
I agree with everything, but two words: "best built".
I've never owned the DFA WR, though I've seen/held it. It's a smallish, light lens, for a 100mm macro. Which is in many ways an advantage (together with WR), but I'm not so sure it is a sign of robust, durable build.
I'm not questioning, just asking... cause the physical impression was not in accordance with your first hand consideration.
I have the FA, the Sigma 105mm, and own/owned three different iterations of the old Tamron 90mm f/2.5.
The former two are a notch over the Tamrons, just because of the dreaded hot spot that sometimes (rarely) appears on the center of the frame with the old f/2.5 Tamron optical layout (because of the flat, fixed rear glass). I haven't seen the light spot once, with the K-1. Because of the missing AA glass in front of the sensor? Can't say.
The FA is a top class lens, and the Sigma 105mm is at least as good. Reportedly better than the Sigma Macro 50mm EX and only slightly inferior to the 70mm (which should be one of the best macros ever). I own all of them, but I don't use very much macro lenses below 90mm, all I can say is that all of them are damn sharp, and that the 50mm has a very ugly bokeh.
Regarding build quality, which is the reason I'm writing these lines, I think the best one should be the Pentax-F 100mm. I have the 50mm, built the same way. Forgetting about the manual focus ring, the innards are robust and use good materials, better than any subsequent generation of Pentax AF lenses. I've used the fifty a lot on film, and I've been not too bothered by the ridiculous ring. I used to set the ring and move the camera back and forth to get the subject in focus. Best technique for high reproduction ratios...
The 100mm should be about the same.
Regarding MF lenses, all of them had decent builds. The first version of the Tamron was one of the best, and because of its diffusion can be found for cheap. Best price/performance ratio in its category, in my opinion. With a working P/KA ring it's also very ergonomic.
I always thought that the DFA non-WR was nice and small, but not very well built, and that the later WR version was better, but only marginally.
This is why I'm asking, as I see you have the chance to compare, but reported a different experience.
In fact, despite having a few other macros in the same focal range, I tried to score a good F version, but always found rather high prices, so in the end I went for a cheap FA, with some strange AF problems.
Fortunately my theory was correct, the limiter was always engaged
It was a cheap fix, and now the lens works a charm (with nicely working limiter and clamp: a nice bonus for this kind of objectives, IMHO).
I don't think I would swap the FA for a recent DFA WR, though my interest is a bit more than merely academical... you never know what could happen tomorrow
Cheers
Paolo
