Originally posted by mapguy The magnification of the lens is the same; I am just seeing less of it, which makes it look like I am closer.
If you are using a K-3 you are seeing 24MP in the crop area instead of 15 MP, so your resolution within the crop is greater. You are in many cases seeing more detail on your subject and less of the surrounding environment. You don't get the same view with a macro lens, that you do with an electron microscope...that doesn't matter as long as you are getting the FoV that you want for the image you are taking.
There is less than a 3% difference between a 24 MP FF with 50mm lens and a 24MP APS-c lens taken with a 35mm lens. The sensor is a crop sensor, the image is not a cropped image, because you can use a wider, smaller, lighter, probably cheaper lens to do the same thing. The only thing that matters is can you get the image with the framing you want.
The difference being from the same position, you might have to use a 150mm lens on FF and a 100mm lens on APS-c, and carry a lot more weight for what many times will be exactly the same image.
Originally posted by mapguy I am using less of the light the lens is letting in, but probably have more sensors in a smaller area, so getting better images than using film.
The total light admitted for the same image is the same. The FF has to be one stop less to use the same ISO and Shutter speed and maintain Depth of Field. For an image with the same Depth of Field, the FF spread half the light over twice the area. If the subject doesn't have the same Depth of Field , it's a different image and you are comparing apples and orange.
---------- Post added 03-03-18 at 09:55 AM ----------
Originally posted by Wasp More importantly, the depth of field indicator marks on an old 35mm lens are of no use on a modern APSC DSLR. Some wide angle lenses have hyperfocal distance marks, like my M 20mm and M 28mm. They show where to focus at f/8 so that everything is in focus out to infinity. For example, my trusty M 28mm has the hyperfocal distance marked as 3m at f/8. The actual value is 3.3m, but it close enough. On APSC, the hyperfocal distance moves out to 4.9m, but let's call it 5m.
So you cheat back a little on APS-c, those markings are never all that accurate in any case. You still get a working ballpark figure. I have used the markings, and they are still reasonably accurate on APS_c. But then, most of my lenses don't even have a hyperlocal scale. I just pick a spot about 1/3 of the way out to infinity to focus on in my viewfinder and use that. IF the DoF concerns you, stop down an extra stop as a precaution.
