Originally posted by btnapa [snip] ... The rule of shooting with slides in the old days was not to overexpose (slight under exposure was always preferred). The same rule applies to digital. Under expose by a 1/2 stop of so. Never over expose as you cannot recover the highlights.
It's true, you don't want to overexpose - but when shooting RAW, the definition of "overexpose" gets a bit tricky. Some RAW shooters routinely add one or two stops to the camera expoure which results in washed-out looking JPGs and right-heavy camera histograms - but also wider dynamic range in the raw files. Which means more shadow detail without clipped highlights. Research "ETTR" - which means Expose To The Right.
With a properly exposed RAW file you *can* recover some of the highlights which appear to be blown out in the JPG version of the file. And because the camera's histogram is for the JPG and not for the RAW file, the histogram can be misleading about what highlight detail may be be available in the RAW. Deliberate underexposure is probably unnecessary for most slides. If the highlights are blown in the slide, obviously, taking an underexposed photo of the slide is not going to bring them back. And if the slide was underexposed, the shadows are going to be quite dense. In my experience, it's a real challenge to try to recover shadow detail from underexposed slides without introducing a lot of digital noise - and if you deliberately underexpose when digitizing the slide, that problem is just going to get worse.
Fortunately, the dynamic range of your camera sensor almost certainly is greater than the dynamic range of the slides, so even if your camera exposure is off a little, the RAW file should still be able to record the full range of values on the slide.
Try to set up your lighting so you can use your camera's base ISO (it may be 100 or 200, I don't know for your camera) at your desired f-stop.
At the required magnification you will have very little depth of field - maybe a couple of millimeters - which has several implications:
- Because the slide film is usually somewhat curved in it's mount, you are going to need a small f-stop to maximize depth-of-field; but as your f-stop gets smaller, defraction increases which hurts sharpness.
- The plane of your sensor must be parallel to the plane of the slide with millimeter accuracy.
- The lens should have a flat plane of focus. Macro lenses generally do; others may not.
No matter how you digitize the slides, they are probably going to need some cleanup in Photoshop (or whatever). Cloning out dust specks is very tedious, so try to get rid of the dust up front. I suggest you photograph a few, then complete your post processing on those before photographing the rest. You don't want find out that the left edge of all 1,500 slides is slightly out of focus because your set up was off.
