Originally posted by honey bo bo Do you end up cropping your shots a great deal?
I see in your shots here and on Flickr you shoot the 55-300 @ f8 or above quite a bit and let the ISO run above 400 during good daylight and the lens is at 300 quite often. You produce some excellent quality shots. I find that a learning experience for me because I've always been hesitant to shoot daylight nature above f5.6 / f5.8 , ISO 200 and try to keep the reach just a bit below the f300. Some of it due to listening to others and some of it my own making instead of looking at results. I do like the way the 55-300's bokeh at wider f stops eliminates the cover you find the critters in most of the time. To me bokeh front & back eliminates the distraction nicely; something like selective hearing around a nagging wife. The shots of the Bucks fighting caught me by surprise as I had been going to shoot some Ice Surfers and my Camera was preset at f8 and I hadn't adjusted my speed yet with an ISO limited to 200. The surroundings are badly cluttered; the deer were moving fast and the forest was darker than the open lake but all in all I got the shots (50) and most were in focus & exposed fairly. I think now that I think a little harder about it I'll set my ISO to 3200 and set the fstop to f8 or f9 keep a little more in focus and be prepared for action. The 55-300 is terrific lens and I use it a lot more than my Bigma.
Thanks for your comments Bruce. I figured some time ago that I would get better results with this lens stopping down at least one stop, and compromising on the ISO and/or shutter speed if necessary. I try to keep the ISO range capped at 1600 or 2000 wherever possible. You've mentioned the other advantage of f8 - more scope for getting the subject in focus.
You'll notice that most of the birds in these samples are perched. There's generally at least a moment when birds are absolutely still when perched; I try to capture that moment, which means that if the stance is right it is possible to drop the shutter speed if necessary. And if the light is good, it doesn't seem to matter a lot whether the image is at 800 or 1600 ISO - DxO does a good job of cleaning up. The priorities might be different when the subject is moving. (And my approach is different when I'm using the FA*300 f4.5. I can open up with confidence with that lens. It's very good at f4.5-5.6 and outstanding at f6.3. I only go to f8 if I need to for DOF, and try to keep the ISO as low as possible.)
I take your point about eliminating distraction by using a narrower DOF. I guess it depends on the scene. Often you get pretty good subject isolation just from having a clear background and/or foreground, but if you've got a critter in the grass or a bird in tree branches (or bucks fighting in the woods) yes the wider aperture may be an advantage.
As for the choice of using 300mm or zooming out a little for better resolution, I haven't done any comparative testing but my sense is that it's better for the subject to fill the frame more. Especially if I am going to crop - which I do most of the time, often heavily. But I've got an open mind about this - interested if someone has done a comparison.
I agree with your point about how much gain can be made from a little judicious PP. I'm no expert but I find that a little tweaking of the tone curve, increasing micro-contrast and a light touch on the clarity slider make a world of difference - especially with a cheaper lens.
Here's a before and after example, comparing a straight conversion from the DNG with a processed and cropped image. K-3 + DA-L 55-300, 260mm (so I did back off a bit!), f8, 1/500th, ISO 1600 - and probably underexposed by at least a stop. (I think the galah chick was off centre in the original because I was using centre-spot AF and concentrating on getting the eye in focus, and I didn't wait to recompose.)
For @Knightyo I should point out that the original image was 6016 x 4000 pixels; crop (to portrait format) is 1869 x 2811. So from about 24mp to about 5.2mp. That's about par for the course, or better, for bird shots with this lens - the galah is a medium-large bird, and the distance was about 7 or 8 metres (say 22-26 feet). If I had been using my old K-30 I would have started with only 16mp, so the same crop would have been only about 3.4mp. With a smaller bird at the same range, the difference would have been even greater. This was one of the biggest gains when I went from the K-30 to the K-3.
