Originally posted by Bob 256 Many thanks folks.
With that, I'll lean the DA direction if I decide on getting a 300mm. I know the Pentax 300mm DA is probably one of the best out there from reviews here and since it is FF, that pretty much settles it for me. . . . .
I can personally testify as to how well built and tough the SMC Pentax-DA* 300mm F4 ED [IF] SDM is
my copy just survived the failure of my carry system without permanent damage to it other than some minor scratches to the lens itself
I have another boo boo, WARNING and seeking help - Page 5 - PentaxForums.com
it fell from roughly hip high onto a cement side walk, the hood, which took the majority of the force of the impact, was forced back along the barrel of the lens.
the lens itself, suffered cosmetically very little but the hood has significant enough damage: the fragments which broke off prevents it from locking securely into place
major lesson learned is not only to devise a " safety system "
BUT
use the safety system at all times
I have now adjusted my safety system so that it is automatically in use anytime I pick up the sling and attached camera body:
https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/362093-...ml#post4227322
________________________
what ever lens you decide to try to purchase, should you become interested in an " experienced " one, I urge you to be sure to check the forum's market place. I have had nothing but good luck in dealing with members of the forum when I used it to purchase " experienced " equipment
no guaranty of course but I wish you similar luck if you chose that option
