Originally posted by normhead Putting a 1.4 TC on the 100 2.8 makes it a 140 ƒ4...
Pentax K-30
According to DoF Master
Online Depth of Field Calculator
100mm , ƒ2.8, @ 10 feet, total DoF .17 feet.
100mm, ƒ4 ---,@ 10 feet, total DoF .47 feet
140mm , ƒ4... , @ 10 feet, total DoF .24 feet
So wide open, more DoF wide open on the 140 ƒ4. From the same position you actually get more DoF wide open with the TC.
Diffraction tends to become an issue at ƒ8 and goes downhill from there.
100mm 15 feet DoF = total DoG 2.16 feet
Back up to 21 feet to keep the framing roughly the same
140mm, 21 feet, ƒ8 - total DoF = 4.28 feet.
You can actually double your DoF without changing your framing by using the TC and backing up, at the same ƒ-stop.
These kinds of things are usually a lot more complex than most people expect.
From HD DA 1,4x Pentax User Manual:
Chapter "Operational Precautions", point 5:
"The rear converter decreses DOF by one f/stop, eg if the aperture is set to f8, the DOF is equivalent to that of f5.6" In case of 2x TC it will probably decreased by 2 f/stops and that is alot imho especially in case of using Pentax M200 f/4. But it is only my opinion and I may of course be wrong.
